2166|2
3243
出现这种现象是怎么回事? [复制链接]
[2015-09-07 16:43:58 - Helloworld] ------------------------------
[2015-09-07 16:43:58 - Helloworld] Android Launch!
[2015-09-07 16:43:58 - Helloworld] adb is running normally.
[2015-09-07 16:43:58 - Helloworld] Performing com.example1.helloworld.MainActivity activity launch
[2015-09-07 16:43:58 - Helloworld] Automatic Target Mode: launching new emulator with compatible AVD 'AVD1'
[2015-09-07 16:43:58 - Helloworld] Launching a new emulator with Virtual Device 'AVD1'
[2015-09-07 16:43:59 - Emulator]
[2015-09-07 16:43:59 - Emulator]   the '-scale ' option is used to scale the emulator window to
[2015-09-07 16:43:59 - Emulator]   something that better fits the physical dimensions of a real device. this
[2015-09-07 16:43:59 - Emulator]   can be *very* useful to check that your UI isn't too small to be usable
[2015-09-07 16:43:59 - Emulator]   on a real device.
[2015-09-07 16:43:59 - Emulator]   there are three supported formats for :
[2015-09-07 16:43:59 - Emulator]   * if is a real number (between 0.1 and 3.0) it is used as a
[2015-09-07 16:43:59 - Emulator]     scaling factor for the emulator's window.
[2015-09-07 16:43:59 - Emulator]   * if is an integer followed by the suffix 'dpi' (e.g. '110dpi'),
[2015-09-07 16:43:59 - Emulator]     then it is interpreted as the resolution of your monitor screen. this
[2015-09-07 16:43:59 - Emulator]     will be divided by the emulated device's resolution to get an absolute
[2015-09-07 16:43:59 - Emulator]     scale. (see -help-dpi-device for details).
[2015-09-07 16:43:59 - Emulator]   * finally, if is the keyword 'auto', the emulator tries to guess
[2015-09-07 16:43:59 - Emulator]     your monitor's resolution and automatically adjusts its window
[2015-09-07 16:43:59 - Emulator]     accordingly
[2015-09-07 16:43:59 - Emulator]     NOTE: this process is *very* unreliable, depending on your OS, video
[2015-09-07 16:43:59 - Emulator]           driver issues and other random system parameters
[2015-09-07 16:43:59 - Emulator]   the emulator's scale can be changed anytime at runtime through the control
[2015-09-07 16:43:59 - Emulator]   console. see the help for the 'window scale' command for details
[2015-09-07 16:44:08 - Helloworld] New emulator found: emulator-5554
[2015-09-07 16:44:08 - Helloworld] Waiting for HOME ('android.process.acore') to be launched...
我运行一个应用,出现上面的提示,就不往下走了。
还有我建了个AVD,好像比屏幕大,显示不下。
请问该如何解决?谢谢!
此帖出自Linux开发论坛
是不是虚拟机分辨率设置过大啊  详情 回复 发表于 2015-9-7 17:44
个人签名为江山踏坏了乌骓马,为社稷拉断了宝雕弓。
227
2392
管理员
是不是虚拟机分辨率设置过大啊
此帖出自Linux开发论坛
加EE小助手好友,
入技术交流群
EE服务号
精彩活动e手掌握
EE订阅号
热门资讯e网打尽
聚焦汽车电子软硬件开发
认真关注技术本身
个人签名111
3243
可能是吧
此帖出自Linux开发论坛
