2452|0
27
对正弦波发生器做时序仿真时总是出现错误 [复制链接]
梦翼师兄,您好  再请教您一个问题 我早上对正弦波发生器做的是功能仿真  做时序仿真时总是出现如下错误:file:///C:\Users\Administrator\AppData\Roaming\Tencent\QQ\Temp\C5CCA6F32E0F43E3A729E6C6CFB9704C.jpgLoading instances fromE:/experiment/Radar/wave_sin/simulation/modelsim/wave_sin_v.sdo
# Loading instances from wave_sin_v.sdo# Loading work.PRIM_GDFF_LOW
# ** Fatal: SDF files require Alteraprimitive library
#   Time: 0 ps Iteration: 0 Instance: /wave_top_tb File:E:/experiment/Radar/wave_sin/wave_top_tb.v
# FATAL ERROR while loading design# Error loading design
注:
我使用的是Modelsim ALTERA STARTER EDITION 10.1d版本
此帖出自FPGA/CPLD论坛
