2958|3
MBed中增加了WIZwiki-W7500 [复制链接]
今天发现MBed中又增加了WIZwiki-W7500,这是一个Cotex-M0内核的MCU,以IOT为应用的开发板。前一段时间一个坛友还推荐过的。下面是MBed网站上的一些基本介绍:
WIZnet WIZwiki Platform based on the WIZnet's MCU. WIZnet WIZwiki-W7500 is a WIZwiki platform board based on the W7500. The IOP4IoT W7500 chip is the one-chip solution which integrates an ARM Cortex-M0, 128KB Flash and hardwired TCP/IP core for various embedded application platform especially internet of things. If you use WIZwiki-W7500 and you will be able to easily develop a prototype. It can be used Arduino shield that can be used in the Arduino, because Arduino pin Compatible. This is using the CMSIS-DAP USB and ISP Header easily available firmware writing.
  • WIZnet W7500
    • ARM® Cortex™-M0 Core 48MHz
    • 128KB Flash memory
    • 16KB to 48 KB SRAM (Min 16KB available if 32KB socket buffer is used, Max 48KB available if no socket buffer is used)
    • Hardwired TCP/IP Core (8 Sockets, MII: Medium-Independent Interface)
    • 12-bit, 8ch ADC
    • 53 I/Os
    • 1ch Watchdog, 4ch Timers and 8ch PWM
    • 3ch UART
    • 2ch SPI
    • 2ch I2C
  • Arduino form-factor
    • Compatible with a wide range of commercially available shields
  • CMSIS-DAP interface firmware
    • Built-in USB drag 'n' drop FLASH programmer
    • USB Virtual COM port for serial terminal
    • CMSIS-DAP interface for programming and debugging from offline tools
  • mbed.org Developer Website
    • Online Compiler
    • High level C/C++ SDK
    • Active developer community
Pinout
WIZwiki-W7500 detail Pinout
WIZwiki-W7500 simple Pinout
此帖出自单片机论坛
已经在用做产品。希望大家多多交流。  详情 回复 发表于 2016-9-2 16:20
6201
恩,蛮不错的。硬件以太网协议栈
此帖出自单片机论坛
6201
现在有了WIZwiki-W7500P 了
此帖出自单片机论坛
6201
已经在用做产品。希望大家多多交流。
此帖出自单片机论坛
