2123|0
430F149下UART1问题 [复制链接]
如题,型号为MSP430F149。遇到的问题是USART1在初始化时ME2无法修改,在仿真过程中ME2的值始终为0。同样的配置方法,USART0没有问题。请教下这是什么问题,急!
代码如下:
#include
u8 kk = 0xaa;
int main( void )
    // Stop watchdog timer to prevent time out reset
    WDTCTL = WDTPW + WDTHOLD;
char  i0;
  BCSCTL1&=~XT2OFF;                  //打开高频晶体振荡器
  BCSCTL2|= SELM1+SELS;
  do
    IFG1 &=~OFIFG;
    for(  i0=0;i0<100;i0++) ;
  while((IFG1&OFIFG)!=0) ;       //检查振荡器是否正常工作
  IFG1&=~OFIFG;
COM_WINCCPortConfiguration();
   _EINT();
  while(1);
    return 0;
void COM_WINCCPortConfiguration(void);
void COM_WINCCPortConfiguration(){
P3SEL     = BIT6 + BIT7; //Set P3.4 and P3.5 as the second function port
    U1CTL    |= SWRST;
    U1CTL    |= CHAR ;
    U1TCTL   |= SSEL1;
    U1BR0     = 0xD0;
    U1BR1     = 0x00;
    U1MCTL    = 0x40;//Set baud rate as 9600(The best choice)
    ME2      |= UTXE1+URXE1;
    U1CTL    &= ~SWRST;
    IE2      |= URXIE1 + UTXIE1;
    IFG2     &= ~UTXIFG1;
