4240|6
484
用proteus8.1测试pwm信号 [复制链接]
四分之一 to 四分之三  PWM
三分之一 to 三分之二
#include "inc/hw_memmap.h"
#include "inc/hw_types.h"
#include "driverlib/debug.h"
#include "driverlib/gpio.h"
#include "driverlib/pwm.h"
#include "driverlib/sysctl.h"
// The error routine that is called if the driver library encounters an error.
#ifdef DEBUG
void
__error__(char *pcFilename, unsigned long ulLine)
#endif
// This example demonstrates how to setup the PWM block to generate signals.
int
main(void)
    unsigned long ulPeriod;
    // Set the clocking to run directly from the crystal.
    SysCtlClockSet(SYSCTL_SYSDIV_1 | SYSCTL_USE_OSC | SYSCTL_OSC_MAIN |
                   SYSCTL_XTAL_6MHZ);
    SysCtlPWMClockSet(SYSCTL_PWMDIV_1);
    // Enable the peripherals used by this example.
    SysCtlPeripheralEnable(SYSCTL_PERIPH_PWM);
    SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOD);
    // Set GPIO D0 and D1 as PWM pins.  They are used to output the PWM0 and
    // PWM1 signals.
    GPIOPinTypePWM(GPIO_PORTD_BASE, GPIO_PIN_0 | GPIO_PIN_1);
    // Compute the PWM period based on the system clock.
    ulPeriod = SysCtlClockGet() / 50000;
    // Set the PWM period to 50 kHz.
    PWMGenConfigure(PWM_BASE, PWM_GEN_0,
                    PWM_GEN_MODE_UP_DOWN | PWM_GEN_MODE_NO_SYNC);
    PWMGenPeriodSet(PWM_BASE, PWM_GEN_0, ulPeriod);
    // Set PWM0 to a duty cycle of 25% and PWM1 to a duty cycle of 75%.
    PWMPulseWidthSet(PWM_BASE, PWM_OUT_0, ulPeriod / 4);
    PWMPulseWidthSet(PWM_BASE, PWM_OUT_1, ulPeriod * 3 / 4);
    // Enable the PWM0 and PWM1 output signals.
    PWMOutputState(PWM_BASE, PWM_OUT_0_BIT | PWM_OUT_1_BIT, true);
    // Enable the PWM generator.
    PWMGenEnable(PWM_BASE, PWM_GEN_0);
    // Loop forever while the PWM signals are generated.
    while(1)
什么时候8.2特别版出来了,就可以试试M0的仿真了。  详情 回复 发表于 2015-3-1 20:53
484
哈哈哈
从图中看到,pwm0和pwm1产生的1/4 and 3/4pwm和程序吻合, 修改其占空比为1/3 and 2/3如图也吻合。  详情 回复 发表于 2015-3-1 17:50
484
四分之一 to 四分之三.PNG (142.19 KB, 下载次数: 0)
三分之一 to 三分之二.PNG (149.32 KB, 下载次数: 0)
哈哈,做这PWM固件库函数的使用测试比在launchpad板子上来的直观,那块板子很多实验 只能在UART中观察来的并不方便,有时候也看不到程序产生的结果。  详情 回复 发表于 2015-3-1 17:52
484
学习Tiva C的坛友,充分利用proteus会加快你学习理解Tiva C固件库的进度。
341
proteus8.1很强大
484
加两个LED,从其闪烁的快慢可指示占空比的大小
24
