2111|0
3416
【MXCHIP Open1081】AD、wifi和lab [复制链接]
今天又看了看wifi相关的一些资料乱人眼啊
决定给前段时间的结果上添加的东东
正好手上有个NTC的模块,使使AD吧
顺道爬墙出去找了一些labview的控件
关于AD的使用,MXCHIP使用的STM32库似乎比较旧
这里使用ADC1的通道1,对应GPIO_PA1
  1. void ADC1_CH1_DMA_Config(void)
  2. {
  3.   ADC_InitTypeDef       ADC_InitStructure;
  4.   ADC_CommonInitTypeDef ADC_CommonInitStructure;
  5.   DMA_InitTypeDef       DMA_InitStructure;
  6.   GPIO_InitTypeDef      GPIO_InitStructure;
  7.   RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_DMA2 | RCC_AHB1Periph_GPIOA, ENABLE);
  8.   RCC_APB2PeriphClockCmd(RCC_APB2Periph_ADC1, ENABLE);
  9. //  DMA_DeInit(DMA2_Stream0);
  10.   /* DMA2 Stream0 channe0 configuration **************************************/
  11.   DMA_InitStructure.DMA_Channel = DMA_Channel_0;
  12.   DMA_InitStructure.DMA_PeripheralBaseAddr = (uint32_t)ADC1_DR_Address;
  13.   DMA_InitStructure.DMA_Memory0BaseAddr = (uint32_t)&ADC_ConvertedValue;
  14.   DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralToMemory;
  15.   DMA_InitStructure.DMA_BufferSize = 2;
  16.   DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;
  17.   DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable;
  18.   DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_HalfWord;
  19.   DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_HalfWord;
  20.   DMA_InitStructure.DMA_Mode = DMA_Mode_Circular;
  21.   DMA_InitStructure.DMA_Priority = DMA_Priority_High;
  22.   DMA_InitStructure.DMA_FIFOMode = DMA_FIFOMode_Disable;
  23.   DMA_InitStructure.DMA_FIFOThreshold = DMA_FIFOThreshold_HalfFull;
  24.   DMA_InitStructure.DMA_MemoryBurst = DMA_MemoryBurst_Single;
  25.   DMA_InitStructure.DMA_PeripheralBurst = DMA_PeripheralBurst_Single;
  26.   DMA_Init(DMA2_Stream0, &DMA_InitStructure);
  27.   DMA_Cmd(DMA2_Stream0, ENABLE);
  28.   /* Configure ADC1 Channe6 pin as analog input ******************************/
  29.   GPIO_InitStructure.GPIO_Pin = GPIO_Pin_1;
  30.   GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AN;
  31.   GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL ;
  32.   GPIO_Init(GPIOA, &GPIO_InitStructure);
  33.   /* ADC Common Init **********************************************************/
  34.   ADC_CommonInitStructure.ADC_Mode = ADC_Mode_Independent;
  35.   ADC_CommonInitStructure.ADC_Prescaler = ADC_Prescaler_Div2;
  36.   ADC_CommonInitStructure.ADC_DMAAccessMode = ADC_DMAAccessMode_Disabled;
  37.   ADC_CommonInitStructure.ADC_TwoSamplingDelay = ADC_TwoSamplingDelay_5Cycles;
  38.   ADC_CommonInit(&ADC_CommonInitStructure);
  39.   /* ADC1 Init ****************************************************************/
  40.   ADC_InitStructure.ADC_Resolution = ADC_Resolution_12b;
  41.   ADC_InitStructure.ADC_ScanConvMode = ENABLE;
  42.   ADC_InitStructure.ADC_ContinuousConvMode = ENABLE;
  43.   ADC_InitStructure.ADC_ExternalTrigConvEdge = ADC_ExternalTrigConvEdge_None;
  44.   ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Right;
  45.   ADC_InitStructure.ADC_NbrOfConversion = 2;
  46.   ADC_Init(ADC1, &ADC_InitStructure);
  47.   /* ADC1 regular channe6 configuration *************************************/
  48.   ADC_RegularChannelConfig(ADC1, ADC_Channel_1, 1, ADC_SampleTime_3Cycles);
  49. //  ADC_RegularChannelConfig(ADC1, ADC_Channel_7, 2, ADC_SampleTime_3Cycles);
  50. /* Enable DMA request after last transfer (Single-ADC mode) */
  51.   ADC_DMARequestAfterLastTransferCmd(ADC1, ENABLE);
  52.   /* Enable ADC1 DMA */
  53.   ADC_DMACmd(ADC1, ENABLE);
  54.
  55.   /* Enable ADC1 */
  56.   ADC_Cmd(ADC1, ENABLE);
  57. }
复制代码
还好一切正常
配置过程和STM32一样,不啰嗦了
结果就出来这个视频了
庆科的WIFI,架构还不是特别明晰
指导文档中只有UDP的代码运行流程,能补充一下TCP/IP的么
此帖出自RF/无线论坛
So TM what......?
