1888|1
90
对比方案赛+SallenKeyButterworth10KhzLPF [复制链接]
Required:
Cutoff Frequency:  10Khz,
Stop band Frequency: 50Khz,
The minimum stop-band attenuation : -45dB;
The maximum pass-band attenuation: -25dB;
Step1:
Step2:
Step3:
Run simulation for step2’s schematic by Matlab .M code :
function vargarout = ButterWorthLPF10KHz(varargin)
clc;
syms R1_S1 R2_S1 C1_S1 C2_S1 R1_S2 R2_S2 C1_S2 C2_S2 S
Z1S1 = R1_S1 + R2_S1*(1/(S*C2_S1))/(R2_S1 + (1/(S*C2_S1)));
Z2S1 = 1/(S*C1_S1);
TRS1 = Z2S1/(Z1S1 + Z2S1);
Z1S2 = R1_S2 + R2_S2*(1/(S*C2_S2))/(R2_S2 + (1/(S*C2_S2)));
Z2S2 = 1/(S*C1_S2);
TRS2 = Z2S2/(Z1S2 + Z2S2);
TR = TRS1*TRS2;
TRN = subs(TR,[R1_S1 R2_S1 C1_S1 C2_S1 R1_S2 R2_S2 C1_S2C2_S2],...
    [11300 154009.1*10^(-9) 12*10^(-9) 3830 7150 9.1*10^(-9) 82*10^(-9)]);
[Num Den] = numden(TRN);
Nump = sym2poly(Num);
Denp = sym2poly(Den);
bode(tf(Nump,Denp));
end
The Bode chart show that our design can really meet ourinitial  spec ,and it’s really veryconvenient for us, engineers, to implement the Filter Design by Webench . andthis tool is also very precious although it’s an online design tool.
对比方案体现在什么地方呢?  详情 回复 发表于 2014-7-31 15:10
6066
92
裸片初长成(初级)
对比方案体现在什么地方呢?
直播时间:4月22日(周二)10:00
直播奖励:京东卡、蓝牙温湿度计、定制水杯
