2218|0
linux内核信号量问题,求助! [复制链接]
今天看linux的内核信号量,有个问题没搞懂,求助大神!
书上说的up( )函数释放信号量的代码:
movl $sem->count,%ecx
lock; incl(%ecx)
jg 1f
lea %ecx,%eax
pushl %edx
pushl %ecx
call __up
popl %ecx
popl %edx
__up( )c函数:
  __attribute__((regparm(3))) void __up(struct semaphore *sem)
wake_up(&sem->wait);
获取信号量的down函数代码
down:
         lock;decl (%ecx)
         jns 1f
        lea %ecx,%eax
       pushl %edx
      pushl %ecx
      call __down
      popl %ecx
      popl  %edx
1:
__down函数的实现如下:
fastcall void __sched __down(struct semaphore * sem)
        struct task_struct *tsk = current;
        DECLARE_WAITQUEUE(wait, tsk);
        unsigned long flags;
        tsk->state = TASK_UNINTERRUPTIBLE;
        spin_lock_irqsave(&sem->wait.lock, flags);
        add_wait_queue_exclusive_locked(&sem->wait, &wait);
        sem->sleepers++;
        for (;;) {
                int sleepers = sem->sleepers;
                 * Add "everybody else" into it. They aren't
                 * playing, because we own the spinlock in
                 * the wait_queue_head.
                if (!atomic_add_negative(sleepers - 1, &sem->count)) {         //这一条语句*
                        sem->sleepers = 0;
                        break;
                sem->sleepers = 1;        /* us - see -1 above */
                spin_unlock_irqrestore(&sem->wait.lock, flags);
                schedule();
        remove_wait_queue_locked(&sem->wait, &wait);
        wake_up_locked(&sem->wait);
        tsk->state = TASK_RUNNING;
假设此时有5个线程阻塞在信号量上,此时sem->count=-5,那么当有一个线程调用up()释放了信号量唤醒了一个阻塞的线程,那么按照以上*号语句处的条件这个被唤醒的线程还是要被挂起,这里是怎么一回事儿?求助.
此帖出自Linux开发论坛
