12630|10
FET430UIF仿真器驱动问题 [复制链接]
今天刚在淘宝上买的FET430UIF仿真器到货了,所以要赶紧拿来试了,145RMB可是下了血本的,刚插上电脑,安装好驱动,显示如下图,然后我就用CCS V5.3 想仿真试下,但是又出现下面的情况,不知道是为什么, 我是驱动没装好么?笔记本是WIN7 64位的。
楼主能发个驱动我吗     详情 回复 发表于 2015-12-2 12:15
608
也许是CCS V5.3和仿真器的版本vcp不匹配吧。
到哪里去下载匹配的驱动不知道额?  详情 回复 发表于 2014-2-21 19:15
到哪里去下载匹配的驱动不知道额?
2781
417
MSP430: Error initializing emulator: Could not find MSP-FET430UIF on specified COM port
http://e2e.ti.com/support/microc ... f/166/t/275794.aspx
It's working now. I rebooted my PC a few times, reinstalled CCS a couple times, rebooted the FET a few times, power down, etc.
2781
417
MSP-FET430UIF "Error initializing emulator: Could not initialize device interface" error in CCS 5.2.1
http://e2e.ti.com/support/microc ... f/166/t/230708.aspx
2781
417
http://e2e.ti.com/support/low_power_rf/f/851/t/167527.aspx
Please disconnect then reconnect the USB cable and try again. If that doesn't work, one of two things might help:
把仿真器重新连接
1) Uninstalling the port . Right click on it in device manager and click uninstall. Don't uninstall the drivers, then disconnect and reconnect the USB cable. The port should reinstall and you can try the Download shortcut again
2) Reassigning the com port - Right click on the COM port in Device manager, click properties, then go to Port Settings -> advanced and select a new port number. Even though it might complain that it is being used, if it doesn't actually show up in device manager as used you can use it. Press ok to reassign it and then disconnect then reconnect the USB cable.
把串口的端口号删除,重新安装驱动或者重新分配端口号
2781
417
2781
417
2781
417
[attachimg]142508[/attachimg]我的电脑是WIN7 64位的 联网也不成功啊,搞了一天了没有进展 郁闷死了, 100多块钱啊  详情 回复 发表于 2014-2-21 22:51
qinkaiabc 发表于 2014-2-21 21:36
http://e2e.ti.com/support/development_tools/code_composer_studio/f/81/t/162410.aspx
楼主能发个驱动我吗
