4424|1
MSP430仿真调试出现问题 [复制链接]
MSP430仿真调试出现问题,我自己设计的板子,调试串口程序,就出现
Fri Aug 30, 2013 15:54:10: Interface dll version 2.4.9.1
Fri Aug 30, 2013 15:54:10: Device : MSP430F149
Fri Aug 30, 2013 15:54:10: External voltage : 0.0 V
Fri Aug 30, 2013 15:54:10: VCC voltage : 3.3 V
Fri Aug 30, 2013 15:54:12: Download complete.
Fri Aug 30, 2013 15:54:12: Loaded debugee: D:\my program\UART\Debug\Exe\uart.d43
Fri Aug 30, 2013 15:54:12: Target reset
Fri Aug 30, 2013 15:54:47: Target reset
Fri Aug 30, 2013 15:54:48: Target reset
Fri Aug 30, 2013 15:54:52: The stack pointer for stack 'Stack' (currently Memory:0x1D4) is outside the stack range (Memory:0x938 to Memory:0xA00)
Fri Aug 30, 2013 15:54:58: Warning: CPU is OFF (Low Power Mode) and interrupts are disabled! Cannot excute Step/Go.
Fri Aug 30, 2013 15:54:58: Unable to execute: driver error.
Fri Aug 30, 2013 15:54:58: The stack pointer for stack 'Stack' (currently Memory:0x1D4) is outside the stack range (Memory:0x938 to Memory:0xA00)
看样子似乎栈溢出了?  详情 回复 发表于 2013-8-30 17:27
6042
195
看样子似乎栈溢出了?
