2258|2
5272
裸片初长成(中级)
下一次的讨论在哪里?将运算放大器用作比较器—此举可行吗 [复制链接]
这个链接:http://www.ti.com.cn/general/cn/docs/gencontent.tsp?contentId=159426
下一次的讨论在哪里?
我所知道的就是输入端的保护。。  详情 回复 发表于 2013-6-1 22:22
5272
裸片初长成(中级)
原来在这里:哪位给翻译一下?
Differential Input Clamps-- can they affect your op amp circuits? Bruce Trump
Mar 21 2012 11:31 AM
Last week we looked at the effect that internal differential input clamp diodes could have on op amps when used as a comparator. I posed a question--can these clamps affect op amp circuits. Op amps should have near zero volts between the two input terminals, right? So these diodes will never forward bias in normal op amp circuits... or will they?
Just a reminder, we’re talking about the differential clamp diodes that may be present in some op amps, see figure 1.
The effect in op amp circuits is often seen in the basic non-inverting amplifier configurations, including a simple G=1 buffer amplifier. Consider a positive-going input step. The output cannot immediately follow the abrupt input voltage change. If the input step is greater than 0.7V, D1 will conduct, disturbing the non-inverting input. During this period when the op amp isslewing to its new output voltage, the current in the input terminal of the op amp will spike to a much higher value, see figure2. Eventually, when the output “catches up” to the input and all will be well again.
Many applications process inherently slow or band-limited signals, well below the slew rate of the op amp so this behavior would never occur. And in other applications, even with fast changing input voltage, the transient in input terminal current does not adversely affect circuit operation. But in some special cases, the pulse of input current can cause problems. One noteworthy situation is in a multiplexed data acquisition system--a simplified case just showing two input channels is shown below.
As the multiplexer switches from channel 1 to channel 2, in this example, U1’s output is required to quickly slew from -5V to +5V. D1 forward biases and the resulting input current transient passes through the multiplexer switch, discharging the voltage on C2. R/C input filters are often used to hold a steady voltage during channel switching but the current pulse partially discharges C2. It will now take additional time for C2 to recharge to the correct input voltage thus slowing down the possible multiplex rate or reducing accuracy.
The solution is to use an op amp without differential clamps for U1. A FET-input amplifier such as the OPA140 has low input bias current (so as to not load the series resistance of the MUX) and no differential input clamps. It’s great for multiplexed inputs. The OPA827 is an extraordinary performer in most applications--FET input, very low noise, high speed and fast settling. But it has differential input clamps so the OPA827 is probably not the best choice for the op amp following a multiplexer. Last week’s blog had some general guidelines on various op amp types with focus on differential clamps. Check it out for more details… Op Amps as Comparators.
I certainly don't want to leave an impression that op amps with differential input clamps are risky and should be avoided. They are not. But with awareness, you can make better-informed selections in the rare instances where they could affect your circuits. Have you found other ways that differential input clamps affect your circuits?
Thanks for reading,
Bruce
24
我所知道的就是输入端的保护。。
【TI有奖直播报名中】
直播时间:4月24日(周四)上午10:00
直播奖励:好礼等您拿!
站点相关: 国产芯 安防电子 汽车电子 手机便携 工业控制 家用电子 医疗电子 测试测量 网络通信 物联网 11
