5703|0
28
裸片初长成(高级)
Encountered a problem loading directory\xxx.out, could not open file [复制链接]
在进入DEBUG时,出现以下提示:
以查找各方面的原因无果
无意间看了编译时的console窗口提示:
gmake: Target `all' not remade because oferrors.
再往上找:
The following symbols areundefined:
1 Assembly Error, No AssemblyWarnings
  _abc
哇,知道了,因为原来想使用嵌入汇编,随意加了句:
asm (" MOVW       DP,#_abc ");
abc是没有经过定义的;
