4871|2
uC/OS-II V2.92 调试Led闪烁时间有问题? [复制链接]
    while (DEF_TRUE) {                                          /* Task body, always written as an infinite loop.           */
        //BSP_LED_Toggle(0);
        OSTimeDlyHMSM(0, 0, 0, 500);
GPIO_SetBits(GPIOE,GPIO_Pin_3);
GPIO_ResetBits(GPIOE,GPIO_Pin_3);
移植到STM32的是uC/OS官网的uC/OS-II V2.92,程序设置Led闪烁1s一次,但是实际调试的时候,Led闪烁的时间是2s一次。给出源代码,希望大家看看是什么问题?
cpu时钟获取:
CPU_INT32U  BSP_CPU_ClkFreq (void)
    RCC_ClocksTypeDef  rcc_clocks;
    RCC_GetClocksFreq(&rcc_clocks);
    return ((CPU_INT32U)rcc_clocks.HCLK_Frequency);
设置SysTick时钟滴答重载值:
    hclk_freq = BSP_CPU_ClkFreq();   /* Determine SysTick reference freq.                        */
    cnts  = hclk_freq / (CPU_INT32U)OS_TICKS_PER_SEC;  /* Determine nbr SysTick increments in OS_TICKS_PER_SEC.    */
    OS_CPU_SysTickInit(cnts);
初始化SsyTick函数及开中断:
void  OS_CPU_SysTickInit (INT32U  cnts)
    OS_CPU_CM3_NVIC_ST_RELOAD = cnts - 1u;
     /* Set prio of SysTick handler to min prio. */
    OS_CPU_CM3_NVIC_PRIO_ST   = OS_CPU_CM3_NVIC_PRIO_MIN;
     /* Enable timer.                                      */
    OS_CPU_CM3_NVIC_ST_CTRL  |= OS_CPU_CM3_NVIC_ST_CTRL_CLK_SRC | OS_CPU_CM3_NVIC_ST_CTRL_ENABLE;
     /* Enable timer interrupt.                            */
    OS_CPU_CM3_NVIC_ST_CTRL  |= OS_CPU_CM3_NVIC_ST_CTRL_INTEN;
我移植uC/OS-II V2.86的版本,没有什么问题,只是V2.92是针对F107评估板的,但是它和F103在时钟模块应该没啥区别啊,初始化RCC后均为72MHz,求学习交流!
我是初学者  来观摩  详情 回复 发表于 2015-2-4 11:09
                                                            /* ------------------------ TICKS ----------------------- */
#define  OS_CFG_TICK_RATE_HZ             200u               /* Tick rate in Hertz (10 to 1000 Hz)                     */
#define  OS_CFG_TICK_TASK_PRIO            10u               /* Priority                                               */
#define  OS_CFG_TICK_TASK_STK_SIZE     10240u               /* Stack size (number of CPU_STK elements)                */
#define  OS_CFG_TICK_WHEEL_SIZE           17u               /* Number of 'spokes' in tick  wheel; SHOULD be prime     */
看看这些设置都是什么
我是初学者  来观摩
