6026|6
853
Sandisk iNAND 了解 [复制链接]
1.1. General Description
iNAND is an Embedded Flash Drive (EFD) designed for mobile handsets and consumer electronic devices. iNAND is a hybrid device combining an embedded thin flash controller and standard MLC NAND flash memory, with an industry standard e.MMC 4.411 interface.
Empowered with a new e.MMC4.41 feature set such as Boot and RPMB partitions, HPI (implemented on MLC products only), and HW Reset the iNAND e.MMC is the optimal device for reliable code and data storage.
Designed specifically for mobile multimedia applications, iNAND is the most mature on board SD/MMC device since 2005, providing mass storage of up to 64GB in JEDEC compatible form factors, with low power consumption and high performance – an ideal solution for multimedia handsets of 2.5G, 3G, 3.5G and 4G.
In addition to the high reliability and high system performance offered by the current iNAND family of products, iNAND offers plug-and-play integration and support for multiple NAND technology transitions, as well as features such as advanced power management scheme.
iNAND uses advanced Multi-Level Cell (MLC) NAND flash technology, enhanced by SanDisk‟s embedded flash management software running as firmware on the flash controller.
iNAND architecture and embedded firmware fully emulates a hard disk to the host processor, enabling read/write operations that are identical to a standard, sector-based hard drive. In addition, SanDisk firmware employs patented methods, such as virtual mapping, dynamic and static wear-leveling, and automatic block management to ensure high data reliability and maximize flash life expectancy.
SanDisk iNAND provides up to 64GB of memory for use in mass storage applications. In addition to the mass-storage-specific flash memory chip, iNAND includes an intelligent controller, which manages interface protocols, data storage and retrieval, error correction code (ECC) algorithms, defect handling and diagnostics, power management and clock control.
iNAND enables multimedia driven applications such as music, photo, video, TV, GPS, games, email, office and other applications.
The breakthrough in performance and design makes iNAND the ideal solution for mobile handset vendors, portable navigation and Automotive Infotainment vendors who require easy integration, fast time to market and high-capacity.
1.2. Plug-and-Play Integration
iNAND optimized architecture eliminates the need for complicated software integration and testing processes and enables a practically plug-and-play integration in the system. The replacement of one iNAND device with another of a newer generation requires virtually no changes to the host. This makes iNAND the perfect solution for platforms and reference designs, as it allows for the utilization of more advanced NAND Flash technology with minimal integration or qualification efforts.
SanDisk iNAND is well-suited to meet the needs of small, low power, electronic devices. With JEDEC form factors measuring 12mm x 16mm (169 balls), and 11.5x13mm (153 balls) compatible with 0.5mm ball pitch, iNAND is fit for a wide variety of portable devices such as multi-media mobile handsets, personal media players, GPS devices and Automotive infotainment (car multimedia and car navigation).
To support this wide range of applications, iNAND is offered with an MMC/SD Interface.
The MMC interface allows for easy integration into any design, regardless of the host (chipset) type used. All device and interface configuration data (such as maximum frequency and device identification) are stored on the device.
Figure 1 shows a block diagram of the SanDisk iNAND with MMC Interface.
1.3. Feature Overview
SanDisk iNAND, with MMC interface, features include the following:
 Memory controller and NAND flash
 Complies with e.MMC Specification Ver. 4.412
 Mechanical design complies with JEDED MO-276C Specification
 Offered in five TFBGA packages of e.MMC 4.413
o 11.5mm x 13mm x 1.0mm (2GB, 4GB,8GB)
o 11.5mm x 13mm x 1.2mm (16GB)
o 12mm x 16mm x 1.0mm (8GB,16GB)
o 12mm x 16mm x 1.2mm (32GB)
o 12mm x 16mm x 1.4mm (64GB)
  • · Operating temperature range: –25C° to +85C°
 Dual power system
 Core voltage (VCC) 2.7-3.6v
 I/O (VCCQ) voltage, either: 1.7-1.95v or 2.7-3.6v
 Up to 64GB of data storage.
 Supports three data bus widths: 1bit (default), 4bit, 8bit.
 Variable clock frequencies of 0-20 MHz, 0-26 MHz (default), 0-52 MHz (high-speed)
 Up to 104 MB/sec bus transfer rate, using 8 parallel data lines at 52 MHz, DDR Mode
 Correction of memory field errors
 Designed for portable and stationary applications that require high performance and reliable data storage
Capacity
SDIN5D1-2G-L
SDIN5D2-4G-L
SDIN5D2-8G-L
SDIN5C2-8G-L
SDIN5D2-16G-L
SDIN5C2-16G-L
SDIN5C2-32G-L
SDIN5C2-64G-L
SDIN5D1-4G-L
SDIN5D1-8G-L
SDIN5C1-8G-L
SDIN5C1-16G-L
SDIN5D1-16G-L
SDIN5C1-32G-L
SDIN5C1-64G-L
  详情 回复 发表于 2013-4-17 16:02
853
是我孤陋寡闻啊。这个inand 其实就是emmc 的一种啊。看这篇文章扫盲一下
853
iNand
iNAND是SanDisk公司研发的存储芯片,可以简单的看成SD卡或MMC卡芯片化。用户完全可以默认他是SD卡或者MMC卡。    相对MLC,iNAND有以下优点:
1、提高性能
1)减少SOC的工作量,节约SOC资源。如果使用MLC做存储,SOC要参与FLASH的坏块管理、ECC校正等管理,会牺牲部分SOC性能,而使用iNAND的话,FLASH的管理工作都有iNAND完成,SOC只在需要时对iNAND进行读写,其他时候完全可以不需要理会iNAND。
2)读写速度快
(1)iNAND内置Cache模块,如果要存储小于4K的小容量文件时,Cache能够帮助用户将速度提高至MLC的10倍左右,并且Cache模块不需要用户控制,只要存储小容量文件,Cache自动启动,非常方便。
(2)iNAND可以将内置的MLC FLASH模拟成为为SLC,是iNAND具有SLC的读写速度及其他性能,从而提高读写速度。
3)产品更可靠稳定iNAND内置掉电保护、Wear leveling等SANDISK专利技术,可以帮助客户提高FLASH的读写寿        命,以及防止系统忽然掉电损坏系统文件,降低产品返修率。
2、降低系统成本
首先因为iNANDZ中选用的FLASH一般都是市场上最新、最先进制程的FLASH,所以iNAND具有一定的价格优势。
其次,iNAND不同容量的封装一致,客户如果某款机型有不同容量的几个型号,那么它PCB只需要做一套即可,可以帮助客户简化工作、提高效率,比如苹果iPHONE有8G、16G等容量产品,他的PCB只需要一套,生产时候贴上对用的iNAND即可。
3、方便采购
采购iNAND时候只需要注意使用的容量,不需要管制程、架构。而很多CPU对普通NAND FLASH不是完全兼容,假如某款CPU最多支持51nm制程的FLASH,如果FLASH厂家产品升级,该客户就可能遇到采购困难等问题,而且市场上也有三星、现代、美 光等公司的产品,他们都是完全遵照JEDEC委员会的标准,产品完全兼容。
4、使用简单,加快贵司产品研发进度
1)对软件工程师而言,FLASH制程改变,其对应驱动也需要随之变化,其程序移植、代码升级都要重新调试,而iNAND的产品驱动完全一样,一次调试成功就无后顾之忧;
2)对应硬件工程师也可能会因为新FLASH要重新布板,增加工作强度,而iNAND不管多大容量,封装都一样,如果贵司产品容量升级,可以直接在原先的PCB上换上更高容量的iNAND即可。
853
eMMC
求助编辑百科名片
eMMC (Embedded MultiMediaCard) 为MMC协会所订立的内嵌式存储器标准规格,主要是针对手机产品为主。eMMC的一个明显优势是在封装中集成了一个控制器,它提供标准接口并管理闪存,使得手机厂商就能专注于产品开发的其它部分,并缩短向市场推出产品的时间。这些特点对于希望通过缩小光刻尺寸和降低成本的NAND供应商来说,具有同样的重要性。
目录
优点
结构
应用
发展趋势
协会简介
编辑本段
优点
eMMC目前是最当红的移动设备本地存储解决方案,目的在于简化手机存储器的设计,由于NAND Flash芯片的不同厂牌包括三星、KingMax、东芝(Toshiba)或海力士(Hynix)、美光(Micron)等,入时,都需要根据每家公司的产品和技术特性来重新设计,过去并没有哪个技术能够通用所有厂牌的NAND Flash芯片。
而每次NAND Flash制程技术改朝换代,包括70纳米演进至50纳米,再演进至40纳米或30纳米制程技术,手机客户也都要重新设计,但半导体产品每1年制程技术都会推陈出新,存储器问题也拖累手机新机种推出的速度,因此像eMMC这种把所有存储器和管理NAND Flash的控制芯片都包在1颗MCP上的概念,逐渐风行起来。
eMMC的设计概念,就是为了简化手机内存储器的使用,将NAND Flash芯片和控制芯片设计成1颗MCP芯片,手机客户只需要采购eMMC芯片,放进新手机中,不需处理其它繁复的NAND Flash兼容性和管理问题,最大优点是缩短新产品的上市周期和研发成本,加速产品的推陈出新速度。
编辑本段
结构
eMMC 结构由一个嵌入式存储解决方案组成,带有MMC (多媒体卡)接口、快闪存储器设备及主控制器—— 所有在一个小型的BGA 封装。接口速度高达每秒52MB,eMMC具有快速、可升级的性能。同时其接口电压可以是1.8v 或者是3.3v。
编辑本段
应用
eMMC现在的目标应用是对存储容量有较高要求的消费电子产品。今年已大量生产的一些热门产品,如Palm Pre、Amazon Kindle II和Flip MinoHD,便采用了eMMC。为了确认这些产品究竟使用了哪类存储器,iSuppli利用拆机分析业务对它们进行了拆解,发现eMMC身在其中。
编辑本段
发展趋势
eMMC规格的标准逐渐从eMMC4.3世代发展到eMMC4.4世代,eMMC4.5即将问世。 未来其他像更进一步的MCP产品也会把Mobile RAM一起包进去,因此要打内嵌式内存之战,也是要看各家内存资源和技术的齐全度。
但以台系内存模块厂而言,目前还在寻找商机的切入点,除非找到愿意全面支持的内存大厂,否则未来可能只能做大陆山寨手机市场。
编辑本段
协会简介
MMC协会是一个开放标准组织,致力于多媒体存储卡(MMC)物理层、功能和接口规范的制定。类似邮票大小的MMC是一种可移动抽取的内存卡,主要应用在手机、数码相机和其它便携消费电子产品中。尽管MMC协会主要关注可移动抽取的内存卡,但是它也支持MMC接口标准在其它嵌入式设备或者可移动抽取式部件或子系统中的应用,如硬盘驱动器 。
于1998年成立的MMCA协会为内存卡厂商、半导体零部件供应商、软件厂商、移动电子设备制造商提供了一个全球性的论坛,加盟这一协会的厂商将携手推动MMC卡和MMC标准在全球的应用。
MMC协会董事会成员:
ATP
华硕
Gemplus
惠普
英飞凌
Intel
Itri
Kingston
Lexar媒体公司
Micron科技
诺基亚
Power Digital Card
三星电子
Silicon Motion
853
从上面可以看出,Inand 和emmc 的关系式什么了
就是inand 式sandisk 公司做的一款符合emmc 标准的一个emmc 存储器!
鄙视我一下。
开始我以为还是两种东西。
呵呵 楼主这么快能找到答案 挺棒了  详情 回复 发表于 2013-4-16 13:07
管理员
回复 5楼 Wince.Android 的帖子
呵呵 楼主这么快能找到答案 挺棒了
加EE小助手好友,
入技术交流群
EE服务号
精彩活动e手掌握
EE订阅号
热门资讯e网打尽
聚焦汽车电子软硬件开发
认真关注技术本身
加油!在电子行业默默贡献自己的力量!:)
227
2392
管理员
闂傚倸鍊搁崐椋庣矆娓氣偓楠炴牠顢曢妶鍡椾粡濡炪倖鍔х粻鎴犲閸ф鐓曢柟閭﹀灱閸ゅ鏌ら弶鎸庡仴闁哄本绋戦埥澶娾枎閹邦喚鈻忛梺璇插閼归箖藝娴兼潙桅闁告洦鍨扮粻鎶芥煕閳╁啨浠﹀瑙勬礈缁辨捇宕掑▎鎴濆濡炪們鍔屽Λ婵嬪极閸愵喖顫呴柣妯虹仛濞堟儳鈹戞幊閸婃洟骞婃惔銏犲姅闂傚倷绀侀悿鍥ь浖閵娧呯焼濞达綀顫夐崣蹇涙煏閸繍妲归柣鎾跺枛閺岋絽顫滈埀顒佺鐠轰警鐎堕柣鎴eГ閻撴洟鏌¢崒婵囩《缂佺姷绮妵鍕閿涘嫭鍣板Δ鐘靛仜椤戝寮崒鐐村殟闁靛濡囪ぐ銊╂⒑鐠囨煡顎楅柛妯荤矒瀹曟垿骞樼紒妯煎幈闂佸綊鍋婇崢濂稿礉閵堝棛绠鹃柛顐墯鐎氾拷闂傚倸鍊搁崐宄懊归崶顒佸剭妞ゆ劧绠戦獮銏ゆ煃鏉炴壆鍔嶆い鏂垮缁辨捇宕掑顑藉亾閸濄儳鐭欓柛鏇ㄥ灠缁狀垶鏌ㄩ悤鍌涘闂傚倸鍊搁崐鐑芥嚄閸洖绠犻柟鍓х帛閸嬨倝鏌曟繛鐐珕闁稿顑夐弻锝夊箛椤掍焦鍎撻梺缁樺笒閻忔岸濡甸崟顖氱闁规惌鍨遍弫楣冩煟鎼淬垻鍟查柟鍑ゆ嫹濠电姷鏁告慨鐑藉极閹间礁纾绘繛鎴旀嚍閸ヮ剦鏁囬柕蹇曞Х椤︻噣鎮楅崗澶婁壕闂佸憡娲﹂崑澶愬春閻愮儤鈷戦悹鎭掑妼濞呮劙鏌熼崙銈嗗
加EE小助手好友,
入技术交流群
EE服务号
精彩活动e手掌握
EE订阅号
热门资讯e网打尽
聚焦汽车电子软硬件开发
认真关注技术本身
直播时间:3月12日(周三)上午10:00
直播奖励:多功能榨汁机、蓝牙音箱、手机支架
