视频讲解
在《ROS2下编写orbbec相机C++ package并Rviz显示》的基础上,继续添加对获取的图像使用YOLO进行目标检测
首先安装YOLO以及相关库
pip3 install ultralytics
使用如下指令测试下yolo安装情况
yolo task=detect mode=predict model=yolov8n.pt source='https://ultralytics.com/images/bus.jpg'
EEWORLDIMGTK1
成功会在当前位置下生成runs,如下图为检测加上标签的图片,确认yolo调用成功
EEWORLDIMGTK2
接下来使用orbbec发布的图像,进行YOLO实时识别
编写yolo识别package
ros2 pkg create --build-type ament_python yolo_target_detection --dependencies rclpy sensor_msgs cv_bridge
指定依赖项 rclpy(ROS 2 Python 客户端库)、sensor_msgs(用于处理图像消息)和 cv_bridge(用于在 ROS 图像消息和 OpenCV 图像之间进行转换)
在src/yolo_target_detection/yolo_target_detection目录下创建一个 Python 脚本,例如yolo_target_detection.py,并添加以下代码:
import rclpy
from rclpy.node import Node
from sensor_msgs.msg import Image
from cv_bridge import CvBridge
import cv2
from ultralytics import YOLO
import numpy as np
from std_msgs.msg import Header
from sensor_msgs.msg import Image as ROSImage
class YoloTargetDetectionNode(Node):
def __init__(self):
super().__init__('yolo_target_detection_node')
# Initialize the YOLOv8 model
self.model = YOLO("yolov8n.pt") # 选择你训练的模型
self.bridge = CvBridge()
# Create a subscriber for RGB image
self.image_sub = self.create_subscription(
Image,
'/rgb_image', # 修改为你订阅的topic
self.image_callback,
# Create a publisher for output image with bounding boxes
self.obb_pub = self.create_publisher(
ROSImage,
'/obb_image',
def image_callback(self, msg):
try:
# Convert ROS Image message to OpenCV image
cv_image = self.bridge.imgmsg_to_cv2(msg, "bgr8")
except Exception as e:
self.get_logger().error(f"Error converting image: {e}")
return
# Perform object detection using YOLOv8
results = self.model(cv_image)
# YOLOv8 returns a list of results, each result is a Results object
result = results[0] # Get the first result (assuming single image inference)
# Get bounding boxes, class IDs, and confidences
boxes = result.boxes.xywh.cpu().numpy() # Bounding boxes (x_center, y_center, width, height)
confidences = result.boxes.conf.cpu().numpy() # Confidence scores
class_ids = result.boxes.cls.cpu().numpy() # Class IDs
labels = result.names # Class names
# Draw bounding boxes on the image
for i, box in enumerate(boxes):
x_center, y_center, width, height = box[:4]
confidence = confidences[i]
class_id = int(class_ids[i]) # Get the class ID
label = labels[class_id] # Get the class label
# Convert center to top-left coordinates for cv2
x1 = int((x_center - width / 2))
y1 = int((y_center - height / 2))
x2 = int((x_center + width / 2))
y2 = int((y_center + height / 2))
# Draw bounding box and label on the image
cv2.rectangle(cv_image, (x1, y1), (x2, y2), (0, 255, 0), 2)
cv2.putText(cv_image, f"{label} {confidence:.2f}", (x1, y1 - 10),
cv2.FONT_HERSHEY_SIMPLEX, 0.6, (255, 0, 0), 2)
# Convert the image with bounding boxes back to ROS message
try:
obb_image_msg = self.bridge.cv2_to_imgmsg(cv_image, encoding="bgr8")
obb_image_msg.header = Header()
obb_image_msg.header.stamp = self.get_clock().now().to_msg()
obb_image_msg.header.frame_id = "camera_frame" # 根据你的相机frame进行调整
# Publish the image with bounding boxes
self.obb_pub.publish(obb_image_msg)
self.get_logger().info("Published object-bound box image.")
self.get_logger().error(f"Error publishing image: {e}")
def main(args=None):
rclpy.init(args=args)
node = YoloTargetDetectionNode()
try:
rclpy.spin(node)
except KeyboardInterrupt:
pass
finally:
node.destroy_node()
rclpy.shutdown()
if __name__ == '__main__':
main()
打开src/yolo_target_detection/setup.py文件,添加以下内容:
[develop]
script_dir=$base/lib/yolo_target_detection
[install]
install_scripts=$base/lib/yolo_target_detection
在终端中执行以下命令构建和安装包:
colcon build --packages-select yolo_target_detection
source install/setup.bash
ros2 run yolo_target_detection yolo_target_detection
打开Rviz及Orbbec节点发布rgb_image消息即可,同时配置Rviz增加新的image显示,订阅消息为obb_image
