5923|17
debug正常,51运算错误 [复制链接]
已经用其他程序试验过了,不是xdata的问题,xdata里的数据能正常使用。我在用51做一个32点的fft。
部分代码如下:
#include
#include
#define  uchar  unsigned  char
#define  uint unsigned int
#define  N 32 //fft点数
float xdata re[32]={0,1,2,3,4,5,6,7,8,9,10,11,12,13,14,15,16,17,18,19,20,21,22,23,24,25,26,27,28,29,30,31};//实部
float xdata im[32]=0;//虚部
uint x[32];
float code RSin[16] = {1.0000,0.9808,0.9239,0.8315,0.7071,0.5556,0.3827,0.1951,0,-0.1951,-0.3827,-0.5556,-0.7071,-0.8315,-0.9239,-0.9808};
float code RCos[16] = {0.0000,0.1951,0.3827,0.5556,0.7071,0.8315,0.9239,0.9808,1.0000,0.9808,0.9239,0.8315,0.7071,0.5556,0.3827,0.1951};
float tempRe;//实部缓存
float tempIm;//虚部缓存
float sinVal = 0;//正弦值
float cosVal = 0;//余弦值
uint s=0;//
uint group_intf = 0;//
uint num =0;//
uint i = 0;//
uint indexA  =0;//
uint indexB = 0;//
uint index_Rotate = 0;//
uint group = 0;//
uint stage = 0;//
uint g =0;//
char TempData[3];
上面是程序用到的主要变量的定义
下面是主体
main()
//倒位序算法
tempRe=re[1];re[1]=re[16];re[16]=tempRe;
tempRe=re[2];re[2]=re[8];re[8]=tempRe;
tempRe=re[3];re[3]=re[24];re[24]=tempRe;
tempRe=re[5];re[5]=re[20];re[20]=tempRe;
tempRe=re[6];re[6]=re[12];re[12]=tempRe;
tempRe=re[7];re[7]=re[28];re[28]=tempRe;
tempRe=re[9];re[9]=re[18];re[18]=tempRe;
tempRe=re[11];re[11]=re[26];re[26]=tempRe;
tempRe=re[13];re[13]=re[22];re[22]=tempRe;
tempRe=re[15];re[15]=re[30];re[30]=tempRe;
tempRe=re[19];re[19]=re[25];re[25]=tempRe;
tempRe=re[23];re[23]=re[29];re[29]=tempRe;
//*****************fft算法*************************//
    stage = 5;
for(s = 0; s < stage; s++)  //级
  group = N/2/(int)(0x01<   group_intf = N / group;  //组间下标间隔
  for(g = 0; g < group; g++)
   num = (int)(0x01 << s);  //组内蝶形数
   for (i = 0; i < num; i++)
    indexA = g * group_intf + i;
    indexB = indexA + (int)(0x01<     index_Rotate = i * (int)(0x01<<(stage-s-1));  //旋转因子下标
    sinVal = RSin[index_Rotate];
    cosVal = RCos[index_Rotate];
    tempRe = (re[indexB] * sinVal - im[indexB] * cosVal);
    tempIm = (re[indexB] * cosVal + im[indexB] * sinVal);
    re[indexB] = re[indexA] - tempRe;
    im[indexB] = im[indexA] - tempIm;
    re[indexA] = re[indexA] + tempRe;
    im[indexA] = im[indexA] + tempIm;
//求实部与虚部的平方和,再开根号
   for(i=0;i<32;i++)
     tempRe=sqrt(re*re+im*im);x=tempRe;
//将结果显示在1602上,用其他程序,1602显示正常
LCD_Init();
LCD_Clear();//清屏
while (1)
for(i=0;i<16;i=i+4)
   TempData[0]=x[i/4]/100;//分解显示信息
   TempData[1]=(x[i/4]%100)/10;
   TempData[2]=(x[i/4]%100)%10;
   LCD_Write_Char(i,0,TempData[0]+48);
   LCD_Write_Char(i+1,0,TempData[1]+48);
   LCD_Write_Char(i+2,0,TempData[2]+48);
   LCD_Write_Char(i+3,0,'#');
  for(i=16;i<32;i=i+4)
   LCD_Write_Char(i-16,1,TempData[0]+48);
   LCD_Write_Char(i-16+1,1,TempData[1]+48);
   LCD_Write_Char(i-16+2,1,TempData[2]+48);
   LCD_Write_Char(i-16+3,1,'#');
  while(1);
最后显示结果“y35#y35#y35#y35#”“y35#y35#y35#y35#”。
怀疑原因在 for(i=0;i<32;i++){tempRe=sqrt(re*re+im*im);x=tempRe;}部分。
若直接用x=re(正常结果,re=469,-15,-15...,-16),则469能够正常显示,后面的显示“y35”。
此帖出自51单片机论坛
for(i=0;i  详情 回复 发表于 2013-4-9 10:31
感觉到大家的热心解答了,找到自己的问题了吗?要不要帮你再问问其他网友?:)  详情 回复 发表于 2013-4-8 12:05
有没有人能告诉我。51做数据运算应该注意什么?
此帖出自51单片机论坛
尽量使用加减法移位等方式代替乘除法,尤其是除法!  详情 回复 发表于 2013-4-7 12:50
1149
回复 沙发 机械绿藤 的帖子
此帖出自51单片机论坛
内容那我的程序错在哪呢?
此帖出自51单片机论坛
7815
56
裸片初长成(中级)
先直接在显示到1602之前,用一组明确的数据填充到tempdata里先,确定1602显示对不对?即使不是1602底层有问题,也可以把问题范围缩小到显示那一部分的代码
此帖出自51单片机论坛
7815
56
裸片初长成(中级)
两个疑问,进入显示死循环之前,求虚实部平方和,为什么好端端要循环32次?
此帖出自51单片机论坛
7815
56
裸片初长成(中级)
2,已经进入死循环,为什么在最后一句还要死循环?
此帖出自51单片机论坛
7815
56
裸片初长成(中级)
还有,为什么1602显示部分,都是显示一个两位数,为什么下半部分加了48,后面就不加了?
此帖出自51单片机论坛
1602显示已测试,如果跳过算法部分,显示正常
之所以循环32次是因为那是一个数组,32个元素。
死循环确实多余了。
上下部分都加了啊。那是为了将数据转换成asci码
[ 本帖最后由 机械绿藤 于 2013-4-7 19:27 编辑 ]
此帖出自51单片机论坛
2856
260
这样的程序能执行通过,我表示怀疑。
//求实部与虚部的平方和,再开根号
   for(i=0;i<32;i++)
看看这一句,x=tempRe;   x在什么地方定义了?还有循环32次求模值后,x最终求的是31次模值
此帖出自51单片机论坛
768
711
回复 楼主 机械绿藤 的帖子
此帖出自51单片机论坛
原程序里,有中括号,不知道复制过来怎么都没有了。循环次数确实错了,但应该不影响运算吧?
我是用手机上论坛,不能针对每位解答我的朋友回复,请大家见谅。
此帖出自51单片机论坛
2856
260
fft计算部分没有问题,你的问题在显示部分。
看看你的循环,一个模值占4位(3位数字+“#”),16个模值占多少位?1602一行能显示几位数字?太狗血了
for(i=0;i<16;i=i+4)
此帖出自51单片机论坛
我只让他显示前八个结果,以检验结果是否正确。
此帖出自51单片机论坛
循环次数没错
此帖出自51单片机论坛
360
此帖出自51单片机论坛
2856
260
for(i=0;i<16;i=i+4)
i+3  应该是x坐标吧。1602一行显示16个字符,所以i+3<16是必须的。你看看自己程序
此帖出自51单片机论坛
i=0,4,8,12,不会超出显示范围,显示部分没有错误,已经测试过了。我怀疑是浮点数与整形转换的问题,但就是查不出来。
此帖出自51单片机论坛
