2589|0
CCePngButtonST按钮类中的一个疑问 [复制链接]
BOOL CCePngButtonST::ImageFromIDResource(UINT nID, LPCTSTR sTR, IImage** pIImage)
        HINSTANCE hInst = AfxGetResourceHandle();
        HRSRC hRsrc = ::FindResource (hInst,MAKEINTRESOURCE(nID),sTR); // type
        if (!hRsrc)
                return FALSE;
        // load resource into memory
        DWORD len = SizeofResource(hInst, hRsrc);
        BYTE* lpRsrc = (BYTE*)LoadResource(hInst, hRsrc);
        if (!lpRsrc)
                return FALSE;
        // Allocate global memory on which to create stream
        HGLOBAL m_hMem = GlobalAlloc(GMEM_FIXED, len);
        BYTE* pmem = (BYTE*)GlobalLock(m_hMem);
        memcpy(pmem,lpRsrc,len);
        IStream* pStream;
        CreateStreamOnHGlobal(m_hMem,FALSE,&pStream);
        // load from stream
        pIImgFactory->CreateImageFromStream(pStream, pIImage);
        // free/release stuff
        GlobalUnlock(m_hMem);
        if(pStream != NULL)pStream->Release();
        FreeResource(lpRsrc);
        if(m_hMem != NULL) GlobalFree(m_hMem);//添加这一行之后,图片没有绘出来;如果没有这一行,占用的内存资源没有释放
        if(!pIImage)
                return FALSE;
        return TRUE;
不知道是不是那个地方我修改的有问题,还是这段代码有问题
