REAL6440的核心板 SMDK6410 # cannot run '/etc/init.d/rcS': No such file or[复制链接]
使用REAL6410的核心板,程序已经正常运行几天了,突然发现不工作了,启动时出现:SMDK6410 # cannot run '/etc/init.d/rcS': No such file or directory注意已经正常运行几天了,不是rcS编写错误。启动时输出如下:
OK
Boot with zImage
Starting kernel ...
Uncompressing Linux....................................................................................................................................... done, booting the kernel.
Linux version 2.6.28.6 (root@ubuntu) (gcc version 4.3.2 (Sourcery G++ Lite 2008q3-72) ) #6 PREEMPT Wed Aug 29 00:18:00 PDT 2012
CPU: ARMv6-compatible processor [410fb766] revision 6 (ARMv7), cr=00c5387f
CPU: VIPT nonaliasing data cache, VIPT nonaliasing instruction cache
Machine: SMDK6410
Memory policy: ECC disabled, Data cache writeback
CPU S3C6410 (id 0x36410101)
S3C24XX Clocks, (c) 2004 Simtec Electronics
S3C64XX: PLL settings, A=800000000, M=532000000, E=24000000
S3C64XX: HCLKx2=266666666, HCLK=133333333, PCLK=66666666
div1: 00000555
mout_apll: source is fout_apll (1), rate is 800000000
mout_epll: source is fout_epll (1), rate is 24000000
mout_mpll: source is mpll (1), rate is 532000000
mmc_bus: source is dout_mpll (1), rate is 44333333
usb-host-bus: source is mout_epll (0), rate is 24000000
uclk1: source is dout_mpll (1), rate is 66500000
spi_epll: source is mout_epll (0), rate is 24000000
sclk_audio0: source is mout_epll (0), rate is 24000000
sclk_audio1: source is mout_epll (0), rate is 24000000
sclk_audio2: source is mout_epll (0), rate is 24000000
irda-bus: source is mout_epll (0), rate is 24000000
Built 1 zonelists in Zone order, mobility grouping on. Total pages: 65024
Kernel command line: noinitrd console=ttySAC0 ubi.mtd=1 root=ubi0:rootfs rootfstype=ubifs init=/linuxrc video=fb:AT070TN83 ppp=none
PID hash table entries: 1024 (order: 10, 4096 bytes)
Console: colour dummy device 80x30
console [ttySAC0] enabled
Dentry cache hash table entries: 32768 (order: 5, 131072 bytes)
Inode-cache hash table entries: 16384 (order: 4, 65536 bytes)
Memory: 256MB = 256MB total
Memory: 254848KB available (3888K code, 824K data, 128K init)
SLUB: Genslabs=12, HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
Calibrating delay loop... 797.90 BogoMIPS (lpj=1994752)
Mount-cache hash table entries: 512
CPU: Testing write buffer coherency: ok
net_namespace: 288 bytes
NET: Registered protocol family 16
S3C6410 Power Management, (c) 2008 Samsung Electronics
S3C6410: Initialising architecture
S3C DMA-pl080 Controller Driver, (c) 2006-2007 Samsung Electronics
Total 32 DMA channels will be initialized.
SCSI subsystem initialized
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
NET: Registered protocol family 2
IP route cache hash table entries: 2048 (order: 1, 8192 bytes)
TCP established hash table entries: 8192 (order: 4, 65536 bytes)
TCP bind hash table entries: 8192 (order: 3, 32768 bytes)
TCP: Hash tables configured (established 8192 bind 8192)
TCP reno registered
NetWinder Floating Point Emulator V0.97 (double precision)
ashmem: initialized
yaffs Aug 29 2012 00:15:09 Installing.
msgmni has been set to 498
alg: No test for stdrng (krng)
io scheduler noop registered
io scheduler anticipatory registered
io scheduler deadline registered
io scheduler cfq registered (default)
io_powerinitialized.
s3c-aes initialized
S3C AES Drvier
Serial: 8250/16550 driver4 ports, IRQ sharing disabled
s3c6400-uart.0: s3c2410_serial0 at MMIO 0x7f005000 (irq = 16) is a S3C6400/10
s3c6400-uart.1: s3c2410_serial1 at MMIO 0x7f005400 (irq = 20) is a S3C6400/10
s3c6400-uart.2: s3c2410_serial2 at MMIO 0x7f005800 (irq = 24) is a S3C6400/10
s3c6400-uart.3: s3c2410_serial3 at MMIO 0x7f005c00 (irq = 28) is a S3C6400/10
brd: module loaded
loop: module loaded
nbd: registered device at major 43
pmem: 1 init
logger: created 64K log 'log_main'
logger: created 256K log 'log_events'
logger: created 64K log 'log_radio'
mcp251x_init(1063): start
PPP generic driver version 2.4.2
PPP Deflate Compression module registered
PPP BSD Compression module registered
SLIP: version 0.8.4-NET3.019-NEWTTY (dynamic channels, max=256).
CSLIP: code copyright 1989 Regents of the University of California.
dm9000 Ethernet Driver
eth0: dm9000 at d088c000,d088c004 IRQ 108 MAC: 00:22:12:34:56:90
libertas_sdio: Libertas SDIO driver
libertas_sdio: Copyright Pierre Ossman
console [netcon0] enabled
netconsole: network logging started
Linux video capture interface: v2.00
Driver 'sd' needs updating - please use bus_type methods
Driver 'sr' needs updating - please use bus_type methods
S3C NAND Driver, (c) 2008 Samsung Electronics
S3C NAND Driver is using hardware ECC.
NAND device: Manufacturer ID: 0xec, Chip ID: 0xd3 (Samsung NAND 1GiB 3,3V 8-bit)
Creating 2 MTD partitions on "NAND 1GiB 3,3V 8-bit":
0x00400000-0x00800000 : "cramfs"
0x00800000-0x40000000 : "ubifs"
UBI: attaching mtd1 to ubi0
UBI: physical eraseblock size: 262144 bytes (256 KiB)
UBI: logical eraseblock size: 258048 bytes
UBI: smallest flash I/O unit: 2048
UBI: VID header offset: 2048 (aligned 2048)
UBI: data offset: 4096
UBI: attached mtd1 to ubi0
UBI: MTD device name: "ubifs"
UBI: MTD device size: 1016 MiB
UBI: number of good PEBs: 4064
UBI: number of bad PEBs: 0
UBI: max. allowed volumes: 128
UBI: wear-leveling threshold: 4096
UBI: number of internal volumes: 1
UBI: number of user volumes: 1
UBI: available PEBs: 0
UBI: total number of reserved PEBs: 4064
UBI: number of PEBs reserved for bad PEB handling: 40
UBI: max/mean erase counter: 2/1
UBI: background thread "ubi_bgt0d" started, PID 984
spi->irq = 151
Max,Min-Speed [33333333, 130208]Hz
Irq=80 IOmem=[0x7f00bfff-0x7f00b000] DMA=[Rx-33, Tx-34]
usbmon: debugfs is not available
ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
s3c2410-ohci s3c2410-ohci: S3C24XX OHCI
s3c2410-ohci s3c2410-ohci: new USB bus registered, assigned bus number 1
s3c2410-ohci s3c2410-ohci: irq 79, io mem 0x74300000
usb usb1: configuration #1 chosen from 1 choice
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 2 ports detected
Initializing USB Mass Storage driver...
usbcore: registered new interface driver usb-storage
USB Mass Storage support registered.
usbcore: registered new interface driver usbserial
USB Serial support registered for generic
usbcore: registered new interface driver usbserial_generic
usbserial: USB Serial Driver core
USB Serial support registered for GSM modem (1-port)
usbcore: registered new interface driver option
option: v0.7.2:USB Driver for GSM modems
s3c-udc : S3C HS USB OTG Device Driver, (c) 2008-2009 Samsung Electronics
s3c-udc : version 15 March 2009 (DMA Mode)
android adb driver
Registered gadget driver 'android_adb'
mice: PS/2 mouse device common for all mice
gpio-keys init
input: gpio-keys as /devices/platform/gpio-keys/input/input0
S3C24XX RTC, (c) 2004,2006 Simtec Electronics
s3c2410_rtc: tick irq 34, alarm irq 92
s3c2410-rtc s3c2410-rtc: rtc disabled, re-enabling
s3c2410-rtc s3c2410-rtc: rtc core: registered s3c as rtc0
i2c /dev entries driver
s3c2440-i2c s3c2440-i2c: slave address 0x10
s3c2440-i2c s3c2440-i2c: bus frequency set to 378 KHz
[tsc2003] tsc2003_attach_adapter.
s3c2440-i2c s3c2440-i2c: i2c-0: S3C I2C adapter
at24 0-0050: 1024 byte 24c08 EEPROM (writable)
sdhci: Secure Digital Host Controller Interface driver
sdhci: Copyright(c) Pierre Ossman
s3c-sdhci s3c-sdhci.0: clock source 0: hsmmc (133333333 Hz)
s3c-sdhci s3c-sdhci.0: clock source 1: hsmmc (133333333 Hz)
s3c-sdhci s3c-sdhci.0: clock source 2: mmc_bus (44333333 Hz)
mmc0: SDHCI controller on samsung-hsmmc [s3c-sdhci.0] using ADMA
sdhci: card inserted.
s3c-sdhci s3c-sdhci.1: clock source 0: hsmmc (133333333 Hz)
s3c-sdhci s3c-sdhci.1: clock source 1: hsmmc (133333333 Hz)
s3c-sdhci s3c-sdhci.1: clock source 2: mmc_bus (44333333 Hz)
mmc1: SDHCI controller on samsung-hsmmc [s3c-sdhci.1] using ADMA
TCP cubic registered
NET: Registered protocol family 17
can: controller area network core (rev 20081130 abi 8)
NET: Registered protocol family 29
VFP support v0.3: implementor 41 architecture 1 part 20 variant b rev 5
s3c2410-rtc s3c2410-rtc: setting system clock to 2012-12-15 10:53:43 UTC (1355568823)
UBIFS: recovery needed
UBIFS: recovery completed
UBIFS: mounted UBI device 0, volume 0, name "rootfs"
UBIFS: file system size: 1034514432 bytes (1010268 KiB, 986 MiB, 4009 LEBs)
UBIFS: journal size: 33546240 bytes (32760 KiB, 31 MiB, 130 LEBs)
UBIFS: media format: 4 (latest is 4)
UBIFS: default compressor: LZO
UBIFS: reserved for root: 5182151 bytes (5060 KiB)
VFS: Mounted root (ubifs filesystem).
Freeing init memory: 128K
mmc1: new high speed SD card at address e624
mmcblk0: mmc1:e624 SU02G 1.84 GiB
mmcblk0: p1
usb 1-1: new full speed USB device using s3c2410-ohci and address 2
s3c-nand: 1 bit(s) error detected, corrected successfully
usb 1-1: configuration #1 chosen from 1 choice
option 1-1:1.0: GSM modem (1-port) converter detected
usb 1-1: GSM modem (1-port) converter now attached to ttyUSB0
option 1-1:1.1: GSM modem (1-port) converter detected
usb 1-1: GSM modem (1-port) converter now attached to ttyUSB1
option 1-1:1.2: GSM modem (1-port) converter detected
usb 1-1: GSM modem (1-port) converter now attached to ttyUSB2
option 1-1:1.3: GSM modem (1-port) converter detected
usb 1-1: GSM modem (1-port) converter now attached to ttyUSB3
option 1-1:1.4: GSM modem (1-port) converter detected
usb 1-1: GSM modem (1-port) converter now attached to ttyUSB4
can't open /dev/tty3: No such file or directory
can't open /dev/tty4: No such file or directory
can't open /dev/tty2: No such file or directory
