2897|0
21
always的敏感信号是clk,描述语句中可以是“="的赋值语句吗? [复制链接]
[讨论] always的敏感信号是clk,描述语句中可以是“="的赋值语句吗?always, reg
DE1的开发板有个LED灯控PWM IP核实验。在PWM核中,有个always的敏感信号是psedge CLK时,描述语句中的左边的寄存器被“="赋值成什么电路?而且该描述语句怎么可以用"="给左边的寄存器赋值呢。按照常理来说,如果敏感信号一般是输入电平信号,描述语句应该采用“=”语句的呀?如果敏感信号是CLK,应该用"<="赋值。哪位大侠能解释下。以下是程序
module pwn(clk,
           reset_n,
           chipselect,
           address,
           write,
           writedata,
           read,
           byteenable,
           readdata,
           PWM_out);
input clk;
input reset_n;
input chipselect;
input [1:0]address;
input write;
input [31:0] writedata;
input read;
input [3:0] byteenable;
output [31:0] readdata;
output PWM_out;
reg [31:0] clock_divide_reg; //Internal register  clock divide
reg [31:0] duty_cycle_reg; //Internal register ;the clock less than duty_cycle_reg pwm_out will be output 1.otherwise will be 0
reg control_reg;
reg clock_divide_reg_selected;
reg duty_cycle_reg_selected;
reg control_reg_selected;
reg [31:0] PWM_counter;
reg [31:0] readdata;
reg PWM_out;
wire pwm_enable;
always @ (address)
begin
   clock_divide_reg_selected<=0;
   duty_cycle_reg_selected<=0;
   control_reg_selected<=0;
   case(address)
       2'b00:clock_divide_reg_selected<=1;
       2'b01:duty_cycle_reg_selected<=1;
       2'b10:control_reg_selected<=1;
    default:
        begin
        end
   endcase
end
always @ (posedge clk or negedge reset_n)
begin
if(reset_n==1'b0)
   clock_divide_reg=0;
else
begin
    if(write & chipselect & clock_divide_reg_selected)
    begin
      if(byteenable[0])
        clock_divide_reg[7:0]=writedata[7:0];
      if(byteenable[1])
        clock_divide_reg[15:8]=writedata[15:8];
      if(byteenable[2])
        clock_divide_reg[23:16]=writedata[23:16];
      if(byteenable[3])
        clock_divide_reg[31:24]=writedata[31:24];
    end
end
end
begin
if(reset_n==1'b0)
   duty_cycle_reg=0;
else
begin
    if(write & chipselect & duty_cycle_reg_selected)
    begin
      if(byteenable[0])
        duty_cycle_reg[7:0]=writedata[7:0];
      if(byteenable[1])
        duty_cycle_reg[15:8]=writedata[15:8];
      if(byteenable[2])
        duty_cycle_reg[23:16]=writedata[23:16];
      if(byteenable[3])
        duty_cycle_reg[31:24]=writedata[31:24];
    end
end
end
begin
if(reset_n==1'b0)
   control_reg=0;
else
begin
    if(write & chipselect & control_reg_selected)
    begin
      if(byteenable[0])
        control_reg=writedata[0];
    end
end
end
最后3个always中的描述语句怎么用的是”=“语句赋值。高步懂。
我知道always行为描述的2输入与门电路,等等
input a,b;
output reg  out;
alwys @(a or b)
begin out=a&b;end//不是”<=“赋值。
此帖出自FPGA/CPLD论坛
