基本的IO配置如下:
P1.0 LED Anode for Bit-Banged RS232 sinal for outputting debug messages
P2.0 Sync-LED Anode
P2.1 Sync-LED Cathode (unimportant, only soldered it in this way to be able to measure brightness later)
P2.2 D- over about 50 Ohms (two 100 Ohms resistors in parallel in my case)
P2.3 D+ over about 50 Ohms
P2.5 Resistor 1.5kOhms to D- as switchable connect/disconnect simulator
XIN feeded with digital external 18 MHz clock. Note that the XO runs with same voltage as MSP430, altough rated for 5V, it works.
D- has to be on a pin that for clock cycle reasons is accessible with the constant generator (the lower four pins) and D+ only has to be on the same port as D-.
