user guide 中文版用户指南向导 007 翻译slau144i
13.2.6 Timer_B Interrupts ............. .............................................. 397 13.3 Timer_B Registers ............. ............. ......... 399 13.3.1 Timer_B Control Register TBCTL ............. ............................ 400 13.3.2 TBR, Timer_B Register ............. ........................................ 401 13.3.3 TBCCRx, Timer_B Capture/Compare Register x ............. ........... 401 13.3.4 TBCCTLx, Capture/Compare Control Register ............. ............. 402 13.3.5 TBIV, Timer_B Interrupt Vector Register ............. .................... 403 14 Universal Serial Interface (USI) ..通用串行接口 ............................ 405 14.1 USI Introduction ............. ............. ............ 406 14.2 USI Operation ............. ............. .............. 409 14.2.1 USI Initialization ...........初始化..... .... .. 409 14.2.2 USI Clock Generation 一代 辈!!!!!!!!!!!..........生成. .................. 409 14.2.3 SPI Mode ............. ............. ......... 410 14.2.4 I 2 C Mode ............. ............. .......... 412 14.3 USI Registers ............. ............. ............... 415 14.3.1 USICTL0, USI Control Register 0 ........... 控制 寄存器 .............. 416 14.3.2 USICTL1, USI Control Register 1 ............. ............................. 417 14.3.3 USICKCTL, USI Clock Control Register . 时钟控制 寄存器 .......... 418 14.3.4 USICNT, USI Bit Counter Register .........位计数器 寄存器 ................. 418 14.3.5 USISRL, USI Low Byte Shift Register .. 低字节 移位寄存器 ... 419 14.3.6 USISRH, USI High Byte Shift Register ............. ....................... 419 15 Universal Serial Communication Interface, UART Mode 通用串行通讯接口,异步模式 ............. ......... 421 15.1 USCI Overview ....... 概述 ........ ............. 422 15.2 USCI Introduction: UART Mode ............. .......... .简介 .................... 422 15.3 USCI Operation: UART Mode ............. ........................................... 424 15.3.1 USCI Initialization and Reset ........ 初始化和复位 ................. 424 15.3.2 Character Format ............. ..........字符格式 ... 424 15.3.3 Asynchronous Communication Formats 异步通信格式 ..................... 424 15.3.4 Automatic Baud Rate Detection ...........波特率自动检测 ............ 427 15.3.5 IrDA Encoding and Decoding ........红外线 编码和解码 ......... 428 15.3.6 Automatic Error Detection ...........误差自动检测 ....... 429 15.3.7 USCI Receive Enable ............. ...接收使 .........使能............ 429 15.3.8 USCI Transmit Enable ............. ..传输让. ..........使能......... 430 15.3.9 UART Baud Rate Generation .............波特率 !!!产生 !!!! ............... 430 15.3.10 Setting a Baud Rate ............. ........设置 波特率 ................... 432 15.3.11 Transmit Bit Timing ............. ............................................ 433 15.3.12 Receive Bit Timing ............. ............................................ 433 15.3.13 Typical Baud Rates and Errors ........典型的波特率和错误 ........ 435 15.3.14 Using the USCI Module in UART Mode with Low Power Modes 低功耗模 方式 对UART模式 使用USCI模块的UART模式,低功耗模式 GGG ...................................... 437 15.3.15 USCI Interrupts ............. ............中断 . . 437 15.4 USCI Registers: UART Mode ............. ....................... .. 寄存器 .................. 439 15.4.1 UCAxCTL0, USCI_Ax Control Register 0 ............. ....... ..控制寄存器 .......... 440 15.4.2 UCAxCTL1, USCI_Ax Control Register 1 ............. ........ 441 15.4.3 UCAxBR0, USCI_Ax Baud Rate Control Register 0 .. 波特率 控制寄存器.... .... 441 15.4.4 UCAxBR1, USCI_Ax Baud Rate Control Register 1 ......... ... 441 15.4.5 UCAxMCTL, USCI_Ax Modulation Control Register ......调制 控制寄存器 ........ ....... 442 15.4.6 UCAxSTAT, USCI_Ax Status Register ............. ...... 状态寄存器 ................ 442 15.4.7 UCAxRXBUF, USCI_Ax Receive Buffer Register ..........接收 缓冲 寄存器 ... .......... 443 15.4.8 UCAxTXBUF, USCI_Ax Transmit Buffer Register ............. .......... 443 15.4.9 UCAxIRTCTL, USCI_Ax IrDA Transmit Control Register ............. . 443 15.4.10 UCAxIRRCTL, USCI_Ax IrDA Receive Control Register ............. 443 15.4.11 UCAxABCTL, USCI_Ax Auto Baud Rate Control Register ..波特率的自动控制 .. 444 15.4.12 IE2, Interrupt Enable Register 2 ............. .................中断使能 ............ 444
[ 本帖最后由 ppiicc 于 2012-11-24 17:47 编辑 ]
