3004|4
171
user guide 中文版用户指南向导 012 翻译slau144i [复制链接]
26.3.3 SD16INCTL0, SD16_A Input Control Register
......... ......... ........... 627
26.3.4 SD16MEM0, SD16_A Conversion Memory Register ......... ......... ... 628
26.3.5 SD16AE, SD16_A Analog Input Enable Register ... ...使能......... .......... 628
26.3.6 SD16IV, SD16_A Interrupt Vector Register ....... .....向量......... ......... 628
27
SD24_A ......... ......... ......... ......... ....................... 629
27.1
SD24_A Introduction ......... ......... ......... ......... . 630
27.2
SD24_A Operation ......... ......... ......... ......... ... 632
27.2.1 ADC Core ......... ......... ......... ......... ... 632
27.2.2 Analog Input Range and PGA ......... ......... ......... ..... 632
27.2.3 Voltage Reference Generator ......... ......... ......... ..... 632
27.2.4 Auto Power-Down ......... ......... ......... ................... 632
27.2.5 Analog Input Pair Selection ......... ......... ......... ........ 632
27.2.6 Analog Input Characteristics ......... ......... ......... ....... 633
27.2.7 Digital Filter ......... ......... ......... ......... . 634
27.2.8 Conversion Memory Register: SD24MEMx ......... ......... .............. 638
27.2.9 Conversion Modes ......... ......... ......... .................. 639
27.2.10 Conversion Operation Using Preload ......... ......... .................... 641
27.2.11 Using the Integrated Temperature Sensor ......... ......... .............. 642
27.2.12 Interrupt Handling ......... ......... ......... ................. 643
27.3
SD24_A Registers ......... ......... ......... ......... ... 645
27.3.1 SD24CTL, SD24_A Control Register ......... ......... ...................... 646
27.3.2 SD24CCTLx, SD24_A Channel x Control Register ......... ...通道 控制寄 ...... ..... 647
27.3.3 SD24INCTLx, SD24_A Channel x Input Control Register ......通道 输入 控制寄 ... 648
27.3.4 SD24MEMx, SD24_A Channel x Conversion Memory Register 通道 转换内存 寄 ... 649
27.3.5 SD24PREx, SD24_A Channel x Preload Register ......... .....通道预登记      .. 649
27.3.6 SD24AE, SD24_A Analog Input Enable Register .........模拟输入 使能寄 .... ....... 649
27.3.7 SD24IV, SD24_A Interrupt Vector Register ......... .......中断向量寄 .. .............. 650
28
Embedded Emulation Module (EEM) .......嵌入式仿真模块 ...... 651
28.1
EEM Introduction ......... ......... ......... ......... ..... 652
28.2
EEM Building Blocks ......... .....块 .... ......... .........  654
28.2.1 Triggers ......... ......... ...触发 ......... ..... 654
28.2.2 Trigger Sequencer ......... ..触发 序列....... ......... .................. 654
28.2.3 State Storage (Internal Trace Buffer)状态存储(内部跟踪缓冲区) ..... 654
28.2.4 Clock Control ......... ......... ......时钟控制 ... ........................ 654
28.3
EEM Configurations ......... ......... .......配置.. ......... . 655
Revision History ........修订历史 ....... ......... ................... 657
这样翻译没有任何意义!看不懂大侠要干嘛  详情 回复 发表于 2012-11-25 22:22
752
这是什么啊?
看不出来
标题 不看?  详情 回复 发表于 2012-11-25 22:01
171
回复 沙发 deweyled 的帖子
标题 不看?
752
回复 板凳 ppiicc 的帖子
这样翻译没有任何意义!看不懂大侠要干嘛
大哥 你看过一遍 官方 的教学视频 再看这啊  详情 回复 发表于 2012-11-26 22:24
171
回复 4楼 deweyled 的帖子
中星联华&ADI明日直播
直播主题:大咖面对面,轻松玩转高速ADC性能测试
直播时间:3月25日(周二)14:00
活动奖励:京东卡、双肩包
