2311|0
171
user guide 中文版用户指南向导 004 翻译slau144i [复制链接]
3.4.4
Instruction Cycles and Lengths 指令周期和长度 ............................... 63
3.4.5
Instruction Set Description .指令集描述 .... ............................... 65
3.4.6
Instruction Set Details .细节 ....................................... 67
CPUX ......................... .......................... 119
4.1
CPU Introduction ................. ............................. 120
4.2
Interrupts .................................... ........................... 122
4.3
CPU Registers ................................... ...................................... 123
4.3.1
Program Counter (PC) ........................................... 123
4.3.2
Stack Pointer (SP) ................................................ 123
4.3.3
Status Register (SR) .............................................. 125
4.3.4
Constant Generator Registers (CG1 and CG2)不断生成寄存器 ..................................... 126
4.3.5
General-Purpose Registers (R4 to R15) 通用寄存器 .............................. 127
4.4
Addressing Modes .............................. 129
4.4.1
Register Mode ..................................................... 130
4.4.2
Indexed Mode ..................................................... 131
4.4.3
Symbolic Mode .................................................... 135
4.4.4
Absolute Mode .................................................... 140
4.4.5
Indirect Register Mode ........................................... 142
4.4.6
Indirect Autoincrement Mode .................................... 143
4.4.7
Immediate Mode .................................................. 144
4.5
MSP430 and MSP430X Instructions ........... .......................... 146
4.5.1
MSP430 Instructions .................................... ............. 146
4.5.2
MSP430X Extended Instructions扩展 .................................. 151
4.6
Instruction Set Description 指令集描述 ............. ........................................ 164
4.6.1
Extended Instruction Binary Descriptions  扩展指令的二进制描述 ................... 165
4.6.2
MSP430 Instructions .............................................. 167
4.6.3
MSP430X Extended Instructions ................................ 219
4.6.4
MSP430X Address Instructions 地址指令 .................... 261
Basic Clock Module+ 基本时钟模块+ ... ............................ 277
5.1
Basic Clock Module+ Introduction ....... ................................. 278
5.2
Basic Clock Module+ Operation ...... ....................................... 280
5.2.1
Basic Clock Module+ Features for Low-Power Applications
基本时钟模块+ 低功率应用..特点   ........................... 281
5.2.2
Internal Very-Low-Power Low-Frequency Oscillator (VLO)
内部very-low-power低频振荡器 ............................ 281
5.2.3
LFXT1 Oscillator .................................................. 281
5.2.4
XT2 Oscillator ..................................................... 282
5.2.5
Digitally-Controlled Oscillator (DCO) ........................... 282
5.2.6
DCO Modulator .................................................... 284
5.2.7
Basic Clock Module+ Fail-Safe Operation .故障安全操作 .................... 284
5.2.8
Synchronization of Clock Signals 时钟信号同步 ................ 285
5.3
Basic Clock Module+ Registers .......................................... 287
5.3.1
DCOCTL, DCO Control Register ............................... 288
5.3.2
BCSCTL1, Basic Clock System Control Register 1 ............................. 288
5.3.3
BCSCTL2, Basic Clock System Control Register 2 ............................. 289
5.3.4
BCSCTL3, Basic Clock System Control Register 3 ............................. 290
5.3.5
IE1, Interrupt Enable Register 1 中断使能寄存器 ............. 291
5.3.6
IFG1, Interrupt Flag Register 1 .中断标志寄存器 .............. 291
DMA Controller 直接存储器存取控制器 .............. 293
6.1
DMA Introduction ................................ 294
6.2
DMA Operation .................................. 296
6.2.1
DMA Addressing Modes ......................................... 296
6.2.2
DMA Transfer Modes ............................................. 297
6.2.3
Initiating DMA Transfers 发起直接存储器存取传输 ........... 303
[ 本帖最后由 ppiicc 于 2012-11-24 17:26 编辑 ]
站点相关: 国产芯 安防电子 汽车电子 手机便携 工业控制 家用电子 医疗电子 测试测量 网络通信 物联网 13
