2410|0
HJ-2G(AVR)矩阵键盘+数码管显示 [复制链接]
为什么(0,1,2,3)在数码管上不显示?
求高人指导
源程序(ICC-AVR)如下:
#include
#include
#define uchar unsigned char
#define uint unsigned int
uchar Key;
#pragma data:code
flash table[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,
0x7d,0x07,0x7f,0x6f,0x77,0x7c,0x39,0x5e,0x79,0x71,0};
void delay(uint ms)
uint i,j;
for(i=0;i   for(j=0;j<1141;j++);
void number_show(uchar num)
PORTB=table[num];
PORTA|=BIT(3);
PORTA&=~BIT(3);
PORTB=0XFF;
PORTB=~BIT(0);
PORTA|=BIT(4);
PORTA&=~BIT(4);
delay(10);
void key_scan()
uchar key,i;
DDRD=0xf0;
PORTD=0x0f;
    key=PIND;
key&=0x0f;
if(key!=0x0f)
   delay(10);
   for(i=0;i<4;i++)
    PORTD=~BIT(i);
    DDRD=0x0f;
    key=PIND;
    key_result(key&0xf0,i);
   //while();
void key_result(uchar keyread,uchar i)
  if(i==0)
   switch(keyread)
    case 0xe0:
             Key=0; break;
     case 0xd0:
          Key=1; break;
    case 0xb0:
          Key=2; break;
    case 0x70:
          Key=3; break;
  else if(i==1)
   switch(keyread)
    case 0xe0:
          Key=4; break;
     case 0xd0:
          Key=5; break;
    case 0xb0:
          Key=6; break;
    case 0x70:
          Key=7; break;
  else if(i==2)
   switch(keyread)
    case 0xe0:
          Key=8; break;
     case 0xd0:
          Key=9; break;
    case 0xb0:
          Key=10; break;
    case 0x70:
          Key=11; break;
  else if(i==3)
   switch(keyread)
    case 0xe0:
          Key=12; break;
     case 0xd0:
          Key=13; break;
    case 0xb0:
          Key=14; break;
    case 0x70:
          Key=15; break;
  else
   Key=16;
void main()
DDRA|=BIT(3);
DDRA|=BIT(4);
DDRB=0XFF;
while(1)
  key_scan();
  number_show(Key);
}HJ-2G原理图
[ 本帖最后由 cxchenxingcool 于 2012-11-13 20:42 编辑 ]
HJ-2G电路原理图.pdf
145.68 KB, 下载次数: 19
HJ-2G电路原理图
