2336|0
msp430F2471串口中断里写不上flash,是什么原因 [复制链接]
#include
void int_sys()
   WDTCTL = WDTPW + WDTHOLD;
  // if (CALBC1_12MHZ ==0xFF || CALDCO_12MHZ == 0xFF)
  //  while(1);                               // If calibration constants erased
                                           // do not load, trap CPU!!
    DCOCTL  = CALDCO_1MHZ;
    BCSCTL1 = CALBC1_1MHZ+0x30;
    BCSCTL2 = 0x00;
    BCSCTL3 = 0x20;
    //delay1ms(1000);
    //DCOCTL  = CALDCO_12MHZ;
    //BCSCTL1 = CALBC1_12MHZ+0x30;
    if (BCSCTL1 == 0xFF)                      // Check flash erasure
         while(1);                               // If DCO constants invalid,trap CPU
    FCTL2 = FWKEY + FSSEL0 + FN1;
  // playsb(0xe7);
   P3SEL=0X30;
  P3SEL |= 0x0C0;    // P3.6,7 = USCI_A1 TXD/RXD
  UCA0CTL1 |=  UCSSEL_2;                       // CLK = ACLK
  UCA0BR0 = 104;                           // 32kHz/9600 = 3.41
  UCA0BR1 = 0;
  UCA0MCTL = UCBRS1 + UCBRS0;               // Modulation UCBRSx = 3
  UCA0CTL1 &= ~UCSWRST;                     // **Initialize USCI state machine**
  IE2 |= UCA0RXIE ;               // Enable USCI_A0 TX/RX interrupt
  UCA1CTL1 |=  UCSSEL_2;                       // SMCLK
  UCA1BR0 = 104;                             // 12MHz 9600
  UCA1BR1 = 0;
  UCA1MCTL =  UCBRS0;                         // Modulation UCBRSx = 1
  UCA1CTL1 &= ~UCSWRST;                     // **Initialize USCI state machine**
  UC1IE |= UCA1RXIE;                          // Enable USCI_A1 RX interrupt
  TA0CCTL0 = CCIE;                           // TA0CCR0 interrupt enabled
  TA0CCR0 = 11400;
  TA0CTL = TASSEL_2 + MC_1;                  // SMCLK, upmode
  _EINT();
void delay1_ms(unsigned int k)
  unsigned int i,m;
  for(m=0;m   {
  for(i=0;i<100;i++)
void s0_send_byte(unsigned char data)
{ while (!(IFG2&UCA0TXIFG));                 // USCI_A0 TX buffer ready?
  UCA0TXBUF = data;
void s1_send_byte(unsigned char data)
  while (!(UC1IFG&UCA1TXIFG));               // USCI_A1 TX buffer ready?
  UCA1TXBUF = data;
// delay1_ms(1);
void write_SegC(unsigned char * value)   //4*64
  char *Flash_ptr;                          // Flash pointer
  unsigned int i;
  Flash_ptr = ( char *)0x1040;               // Initialize Flash pointer
  FCTL3 = FWKEY;                            // Clear Lock bit
  FCTL1 = FWKEY + ERASE + EEI;              // Set Erase bit, allow interrupts
  *Flash_ptr = 0;                           // Dummy write to erase Flash seg
  FCTL1 = FWKEY + WRT;
  for (i = 0; i < 64; i++)
    *Flash_ptr++ = value;                   // Write value to flash
  FCTL1 = FWKEY;                            // Clear WRT bit
  FCTL3 = FWKEY + LOCK;                     // Set LOCK bit
void  read_SegC(unsigned char * p)
  unsigned char *ptrd;
  unsigned char i;
  ptrd = (unsigned char *)0x1040;
for(i=0;i<64;i++)
  *p=*ptrd;
  p++;
  ptrd++;
void dof(void)
{unsigned char i;
unsigned char p[64];
for(i=10;i<74;i++) p[i-10]=i;
write_SegC(p);
i=0;
void main( void )
  unsigned char i,ADDR;
  int_sys();
// BEEP_1;
// delay_1us(2000);
   //BEEP_0;
        //读黑名单
  read_SegC(p);
  i=0;
   dof();
while(1)
#pragma vector = USCIAB0RX_VECTOR
__interrupt void USCIAB0RX_ISR(void)  ///RC522
// s0_send_byte(UCA0RXBUF);
dof();
#pragma vector=USCIAB1RX_VECTOR        //上位机
__interrupt void USCI1RX_ISR(void)
///15829748923
// Timer A0 interrupt service routine
#pragma vector=TIMERA0_VECTOR
__interrupt void Timer_A (void)
  //TM_1MS++;
  //if(TM_1MS==100) { TM_1MS=0;BEEP_0;}
  //if(TM_1MS==20000) {/ p(0xf6,0x00,0x00);
  //  TM_1MS=0;}
  //    if(TM_1MS==60000) TM_1MS=0;
#pragma vector=PORT2_VECTOR
__interrupt void Port2()
if((P2IFG&BIT4) == BIT4)
  P2IFG &= ~BIT4; //清除中断标志
//用户代码
  ++btime;
直播时间:4月22日(周二)10:00
直播奖励:京东卡、蓝牙温湿度计、定制水杯
