3064|3
62
实在是没办法了请高手帮帮忙啊 [复制链接]
最近在弄430I2C协议,不知道那里出问题了总是调不出来,我已经调试了两天了,今天测试程序连往芯片里写都没法写根本检测不到应答信号。使用的是MSP430F1611,晶振使用的4M晶振。希望有高手能帮我看看程序。
程序.zip
4.78 KB, 下载次数: 4
430程序
以前写过,拿出来参考下 void I2C_init(void) {     SET(PT(I2C_SCL_PORT,DIR,I2C_SCL_BIT));     CLR(PT(I2C_SCL_PORT,OUT,I2C_SCL_BIT)); } void I2C_wait(void) {     asm("NOP");     asm("NOP");     asm("NOP");     asm("NOP");     asm("NOP");     asm("NOP");     asm("NOP");     asm("NOP"); } void I2C_ack(void) {     SET(PT(I2C_SDA_PORT,DIR,I2C_SDA_BIT));        PT(I2C_SDA_PORT,OUT,I2C_SDA_BIT) = 0;     I2C_wait();         PT(I2C_SCL_PORT,OUT,I2C_SCL_BIT) = 1;     I2C_wait();         PT(I2C_SCL_PORT,OUT,I2C_SCL_BIT) = 0;     I2C_wait();     PT(I2C_SDA_PORT,OUT,I2C_SDA_BIT) = 1; } void I2C_noack(void) {     SET(PT(I2C_SDA_PORT,DIR,I2C_SDA_BIT));     PT(I2C_SDA_PORT,OUT,I2C_SDA_BIT) = 1;     I2C_wait();         PT(I2C_SCL_PORT,OUT,I2C_SCL_BIT) = 1;     I2C_wait();         PT(I2C_SCL_PORT,OUT,I2C_SCL_BIT) = 0;     I2C_wait();     PT(I2C_SDA_PORT,OUT,I2C_SDA_BIT) = 1; } unsigned char I2C_start(void) //在scl高电平过程中,sda产生一个下降沿 {     SET(PT(I2C_SDA_PORT,DIR,I2C_SDA_BIT));     SET(PT(I2C_SDA_PORT,OUT,I2C_SDA_BIT));     I2C_wait();         SET(PT(I2C_SCL_PORT,OUT,I2C_SCL_BIT));     I2C_wait();         CLR(PT(I2C_SDA_PORT,DIR,I2C_SDA_BIT));     if(PT(I2C_SDA_PORT,IN,I2C_SDA_BIT) == 0)// SDA 为低,则说明有其他设备使用sda       return 0;         SET(PT(I2C_SDA_PORT,DIR,I2C_SDA_BIT));     PT(I2C_SDA_PORT,OUT,I2C_SDA_BIT) = 0; //产生一个下降沿     I2C_wait();         PT(I2C_SCL_PORT,OUT,I2C_SCL_BIT) = 0;     I2C_wait();     PT(I2C_SDA_PORT,OUT,I2C_SDA_BIT) = 1;         return 1; } void I2C_stop(void) {     SET(PT(I2C_SDA_PORT,DIR,I2C_SDA_BIT));     PT(I2C_SDA_PORT,OUT,I2C_SDA_BIT) = 0;     I2C_wait();         PT(I2C_SCL_PORT,OUT,I2C_SCL_BIT) = 1;     I2C_wait();     PT(I2C_SDA_PORT,OUT,I2C_SDA_BIT) = 1; // rasing edge     I2C_wait();         PT(I2C_SCL_PORT,OUT,I2C_SCL_BIT) = 0;     I2C_wait();     PT(I2C_SDA_PORT,OUT,I2C_SDA_BIT) =1; } unsigned char I2C_waitack(void) {     unsigned int x = 0xffff;     SET(PT(I2C_SDA_PORT,DIR,I2C_SDA_BIT));     SET(PT(I2C_SDA_PORT,OUT,I2C_SDA_BIT));     I2C_wait();     CLR(PT(I2C_SDA_PORT,DIR,I2C_SDA_BIT));     I2C_wait();         PT(I2C_SCL_PORT,OUT,I2C_SCL_BIT) = 0;     I2C_wait();     PT(I2C_SCL_PORT,OUT,I2C_SCL_BIT) = 1;             while(PT(I2C_SDA_PORT,IN,I2C_SDA_BIT) == 1)     {         x--;         if(!x)         {             PT(I2C_SCL_PORT,OUT,I2C_SCL_BIT) = 0;             return 0;         }     }         PT(I2C_SCL_PORT,OUT,I2C_SCL_BIT) = 0;     SET(PT(I2C_SDA_PORT,DIR,I2C_SDA_BIT));     return 1; } void I2C_send_bit(unsigned char value) {     SET(PT(I2C_SDA_PORT,DIR,I2C_SDA_BIT));         if(value != 0)         PT(I2C_SDA_PORT,OUT,I2C_SDA_BIT) = 1;     else         PT(I2C_SDA_PORT,OUT,I2C_SDA_BIT) = 0;     I2C_wait();         PT(I2C_SCL_PORT,OUT,I2C_SCL_BIT) = 1;     I2C_wait();         PT(I2C_SCL_PORT,OUT,I2C_SCL_BIT) = 0;     I2C_wait();     PT(I2C_SDA_PORT,OUT,I2C_SDA_BIT) = 1; //拉高sda,不影响其他设备使用sda } void I2C_send_byte(unsigned char value,unsigned char order) {     unsigned char i;     SET(PT(I2C_SDA_PORT,DIR,I2C_SDA_BIT));         if(order == 1) //先发送高位,在发送低位     {         for(i=0; i  详情 回复 发表于 2012-10-14 19:27
755
可以用示波器看看430输出的波形是否满足24C02的访问时序
62
用示波器没看出波形来,可能是不大会用吧,我这里调试也挺麻烦的,几个人共用一个仿真器,示波器这边还没有,还得去别的地方用。
44
以前写过,拿出来参考下
void I2C_init(void)
void I2C_wait(void)
    asm("NOP");
    asm("NOP");
    asm("NOP");
    asm("NOP");
    asm("NOP");
    asm("NOP");
    asm("NOP");
    asm("NOP");
void I2C_ack(void)
    I2C_wait();
    I2C_wait();
    I2C_wait();
    I2C_wait();
    I2C_wait();
    I2C_wait();
    I2C_wait();
    I2C_wait();
      return 0;
    I2C_wait();
    I2C_wait();
    return 1;
void I2C_stop(void)
    I2C_wait();
    I2C_wait();
    I2C_wait();
    I2C_wait();
    I2C_wait();
    I2C_wait();
    I2C_wait();
        x--;
        if(!x)
            return 0;
    return 1;
    if(value != 0)
    else
    I2C_wait();
    I2C_wait();
    I2C_wait();
    unsigned char i;
        for(i=0; i<8; i++)
            I2C_send_bit(value & 0x80);
            value <<= 1;
    else//先发送低位,再发送高位
        for(i=0; i<8; i++)
            I2C_send_bit(value & 0x01);
            value >>= 1;
unsigned char I2C_receive_bit(void)
    unsigned char c;
    I2C_wait();
    if(PT(I2C_SDA_PORT,IN,I2C_SDA_BIT) == 1)
        c = 1;
    else
        c = 0;
    I2C_wait();
    return c;
unsigned char  I2C_receive_byte(unsigned char order)
    unsigned char i, value = 0;
    SET(PT(I2C_SDA_PORT,OUT,I2C_SDA_BIT)); //将sda拉高,防止影响
    if(order == 1) //数据从高位开始接收
        for(i = 0; i < 8; i++)
            value <<= 1;
            if(I2C_receive_bit() == 1)
                value |= 0x01;
    else//数据从低位开始接收
        for(i = 0;i < 8; i++)
            value >>= 1;
                value |= 0x80;
    return value;
set就是 置1, clr 就是置0: 希望对你有帮助
