2418|1
101
关于LM4F232例程 [复制链接]
以下是网上看到的例程:
没能理解,求解。
int
main(void)
    volatile unsigned long ulLoop;
    // Enable the GPIO port that is used for the on-board LED.
    SYSCTL_RCGC2_R = SYSCTL_RCGC2_GPIOG;
    // Do a dummy read to insert a few cycles after enabling the peripheral.
    ulLoop = SYSCTL_RCGC2_R;
    // Enable the GPIO pin for the LED (PG2).  Set the direction as output, and
    // enable the GPIO pin for digital function.
    GPIO_PORTG_DIR_R = 0x04;
    GPIO_PORTG_DEN_R = 0x04;
    // Loop forever.
    while(1)
        // Turn on the LED.
        GPIO_PORTG_DATA_R |= 0x04;
        // Delay for a bit.
       for(ulLoop = 0; ulLoop < 20; ulLoop++)
        // Turn off the LED.
        GPIO_PORTG_DATA_R &= ~(0x04);
        // Delay for a bit.
很简单,就是一个LED的闪灯程序  详情 回复 发表于 2012-10-7 21:46
很简单,就是一个LED的闪灯程序
