The BeagleBone-HDMI Cape is designed to provide HDMI interface for BeagleBone.This board features a standard HDMI connector that can be connected to a monitor with a standard HDMI connector using a HDMI cable. The cape also provides touchscreen capability for use for BeagleBone board,features a 4.3'' or 7''inch LCD panel with 20bit that is also a 4-wire resistive touchscreen.The 7''screen can display up to 800x480 and the 4.3''screen can display up to a resolution of 480x272 .However, the function of HDMI and LCD interface is multiplexing ,that is to say ,when using HDMI interface to connect a HD display , users can not use LCD function and vice versa ,Cutbacks are made for the Ethernet connector so the BeagleBone-HDMI Cape can fit perfectly on the BeagleBone board.
BeagleBone-HDMI CAPE
l Physical feature: 78mm*54mm
l Working Temperature: 0 to +70 ℃
l Power supply: 3.3V or 5V
l A couple expansion connectors for Beagle-Bone
l A 50 Pins FPC connector, HDMI Type A interface
l Input: LCD Controller Signals
l Output: High Definition Multimedia Interface (HDMI), LCD signals
l Video resolutions up to 1080p ,support UXGA
l 3D-capable at 720p/60,1080/60, and 1080p/24 frame-pack
l Consumer Electronics Control interface incorporates an HDMI-compliant CEC I/O with hardware protocol and arbitration logic, and requires no external calibration
l Single slave I2C from host, passing through to master I2C interface for DDC connection
l 2:1 and 4:1 down-sampling to handle 96-kHz and 192-kHz audio streams
l Apply to BeagleBone, Devkit8000,Devkit8500 and Devkit8600
l Linux OS and Wince OS supported
BH-CAPE-LCD70T BH-CAPE-LCD43T
Features Features
Screen Size: 7''inch Screen Size: 4.3''inch
Dimension:181.0mm * 120.0mm Dimension:181.0mm * 120.0mm
View Area:168mm * 112mm View Area:168mm * 112mm
Resolution:800x480 Resolution:480x272
Operation temperature:-10~60°C Operation temperature:-10~60°C
Storage Temperature:-20~70°C Storage Temperature:-20~70°C
4-wire resistive touchscreen 4-wire resistive touchscreen
