2828|0
27
PIC单片机编译后的提示的含义 [复制链接]
我用的是PIC12F509单片机,编译程序后,提示如下,对于下面的提示的含义,还不甚明了,特别是
Extra space:
    STRING               used    3Ah (    58) of     1h unit    (5800.0%)
这句,是不是预示着,我的空间不够使用??请教各位朋友了,谢谢
Clean: Deleting intermediary and output files.
Clean: Deleted file "E:\PIC_Project\DSK_20\DSK_20_508\main.obj".
Clean: Deleted file "E:\PIC_Project\DSK_20\DSK_20_508\main.cce".
Clean: Deleted file "DSK_20_508.cof".
Clean: Done.
Executing: "D:\Project_soft\Mplab\setup\PICC\bin\picc.exe" -C -E"main.cce" "main.c" -O"main.obj" -Zg9 -O -ASMLIST -Q -MPLAB -12F509
Advisory[1209]   : An old MPLAB tool suite plug-in was detected. Some options may not work correctly
Advisory[1210]   : Visit www.htsoft.com or contact support@htsoft.com for an update
Executing: "D:\Project_soft\Mplab\setup\PICC\bin\picc.exe" -E"DSK_20_508.lde" "E:\PIC_Project\DSK_20\DSK_20_508\main.obj" -M"DSK_20_508.map" -O"DSK_20_508.cof" -O"DSK_20_508.hex" -Q -MPLAB -12F509
Memory Usage Map:
Program space:
    CODE                 used   16Ah (   362) of   400h words   ( 35.4%)
    ENTRY                used    15h (    21) of   400h words   (  2.1%)
Data space:
    BANK0                used    18h (    24) of    19h bytes   ( 96.0%)
    BANK1                used     0h (     0) of    10h bytes   (  0.0%)
    COMBANK              used     0h (     0) of    10h bytes   (  0.0%)
EEPROM space:
                         None available
ID Location space:
    IDLOC                used     0h (     0) of     4h bytes   (  0.0%)
Configuration bits:
    CONFIG               used     1h (     1) of     1h word    (100.0%)
Extra space:
Summary:
    Program space        used   17Fh (   383) of   400h words   ( 37.4%)
    Data space           used    18h (    24) of    30h bytes   ( 50.0%)
    EEPROM space         None available
    ID Location space    used     0h (     0) of     4h bytes   (  0.0%)
    Configuration bits   used     1h (     1) of     1h word    (100.0%)
Loaded E:\PIC_Project\DSK_20\DSK_20_508\DSK_20_508.cof.
BUILD SUCCEEDED: Mon Aug 20 15:21:29 2012
