3528|4
launchpad语音调试 [复制链接]
今天调了语音模块,大家交流下
#include
#include
#define  uchar   unsigned char
#define  uint    unsigned int
#define  ulong  unsigned long
#define CPU_F ((double)8000000)
#define delay_us(x) __delay_cycles((long)(CPU_F*(double)x/1000000.0))
#define delay_ms(x) __delay_cycles((long)(CPU_F*(double)x/1000.0))
#define TEXTLEN      100  //固定文字的长度
#define HEADLEN       5  //数据包头的长度
#define LEN_OFFSET    2  //长度字节的偏移量(本例中长度不超过255字节,因此只使用1字节长度)
#define K0 (P1IN&BIT0)
//数据包头(0xFD + 2字节长度 + 1字节命令字 + 1字节命令参数)
uchar head[HEADLEN] = {0xfd,0x00,0x00,0x01,0x18};//文字(中间有需要变化的内容可在发送前修改)
//uchar text[TEXTLEN] = {"18700946151"};
uchar xor = 0;
void clock_int()
  WDTCTL = WDTPW +WDTHOLD;                  // Stop Watchdog Timer
  if (CALBC1_1MHZ ==0xFF || CALDCO_1MHZ == 0xFF)
    while(1);                               // If calibration constants erased
                                            // do not load, trap CPU!!
//1Mhz
  BCSCTL1 = CALBC1_1MHZ;                    // Set range
  DCOCTL = CALDCO_1MHZ;                     // Set DCO step + modulation */
void io_int()
  P1OUT = 0x00;
  P1DIR = BIT0;
  P1SEL = BIT1 + BIT2 ;                     // P1.1 = RXD, P1.2=TXD
  P1SEL2 = BIT1 + BIT2 ;                    // P1.1 = RXD, P1.2=TXD
void uart_int()
  UCA0CTL1 |= UCSSEL_1;                     // SMCLK
  UCA0BR0 = 3;                             // 1MHz 19200
  UCA0BR1 = 0;                              // 1MHz 19200
  UCA0MCTL =  UCBRS1 + UCBRS0;                        // Modulation UCBRSx = 1
  UCA0CTL1 &= ~UCSWRST;                     // **Initialize USCI state machine**
  IE2 |= UCA0RXIE+ UCA0TXIE;                          // Enable USCI_A0 RX interrupt
void   R_S_Byte(char R_Byte)
    while(!(IFG2 & UCA0TXIFG));   //????????
    UCA0TXBUF=R_Byte;
void yuyin(uchar* text)
    uint i;
    uchar b[TEXTLEN+1];
    xor = 0;        //校验码初始化
    for(i=0;i=text;
    for(i=strlen(text);i=' ';b[TEXTLEN]='\0';
    head[LEN_OFFSET] = TEXTLEN + 3;  //计算正文长度(1命令字 + 1命令参数 + 文字长度 + 1校验位)
    //发送数据包头(0xFD + 2字节长度 + 1字节命令字 + 1字节命令参数)
    for(i = 0; i < HEADLEN; i++)
        {xor ^= head;R_S_Byte(head);}
    //发送文字内容
    for(i = 0; i < TEXTLEN; i++)
        {xor ^= b;R_S_Byte(b);}
    R_S_Byte(xor);     //发送校验位
    delay_ms(20000);
void main( void )
  // Stop watchdog timer to prevent time out reset
  WDTCTL = WDTPW + WDTHOLD;
  clock_int();
  io_int();
  uart_int();
  while(1)
     //  yuyin("[v8][m6][n1][y0]3243254543256");
       yuyin("45476879870");
什么语音模块,图  详情 回复 发表于 2012-8-13 11:55
55
语音模块?
27
用的什么语音模块啊
1632
什么都不讲,就贴个程序是什么意思?
121
什么语音模块,图
