3268|3
337
一个驱动函数的用途 [复制链接]
最近看ZLG 的CAN例程,里面有个GPIOPinconfigure()函数,但是我看了GPIO的驱动函数库,没有发现有这样一个函数。请问这个函数在哪里有说明文档。
最新库的gpio.c文件里//***************************************************************************** // //! Configures the alternate function of a GPIO pin. //! //! \param ulPinConfig is the pin configuration value, specified as only one of //! the \b GPIO_P??_??? values. //! //! This function configures the pin mux that selects the peripheral function //! associated with a particular GPIO pin.  Only one peripheral function at a //! time can be associated with a GPIO pin, and each peripheral function should //! only be associated with a single GPIO pin at a time (despite the fact that //! many of them can be associated with more than one GPIO pin). //! //! The available mappings are supplied on a per-device basis in //! pin_map.h.  The \b PART_IS_ define will enable the //! appropriate set of defines for the device that is being used. //! //! \note This function is not valid on Sandstorm, Fury, and Dustdevil-class //! devices. //! //! \return None. // //***************************************************************************** void GPIOPinConfigure(unsigned long ulPinConfig) {     unsigned long ulBase, ulShift;     //     // Check the argument.     //     ASSERT(((ulPinConfig >> 16) & 0xff) < 15);     ASSERT(((ulPinConfig >> 8) & 0xe3) == 0);     //     // Extract the base address index from the input value.     //     ulBase = (ulPinConfig >> 16) & 0xff;     //     // Get the base address of the GPIO module, selecting either the APB or the     // AHB aperture as appropriate.     //     if(HWREG(SYSCTL_GPIOHBCTL) & (1 << ulBase))     {         ulBase = g_pulGPIOBaseAddrs[(ulBase << 1) + 1];     }     else     {         ulBase = g_pulGPIOBaseAddrs[ulBase << 1];     }     //     // Extract the shift from the input value.     //     ulShift = (ulPinConfig >> 8) & 0xff;     //     // Write the requested pin muxing value for this GPIO pin.     //     HWREG(ulBase + GPIO_O_PCTL) = ((HWREG(ulBase + GPIO_O_PCTL) &                                     ~(0xf << ulShift)) |                                    ((ulPinConfig & 0xf) << ulShift)); }  详情 回复 发表于 2012-7-19 14:07
你的驱动库可能比较旧,下载新的 Stellarisware 里边有。 这个函数主要是配置管脚复用的。  详情 回复 发表于 2012-7-19 13:27
1803
回复 楼主 ZHANGXUEJIE 的帖子
这个函数主要是配置管脚复用的。
2002
24
最新库的gpio.c文件里
337
谢谢各位!
