ADC12CLK = SMCLK = 5MHz时的寄存器设置
我想用DCO + FLL来得到较为稳定的5MHz,所以设置了一下寄存器: - void Clock_Initial(void){
- WDTCTL = WDTPW + WDTHOLD;
- P2SEL |= BIT2;
- P2DIR |= BIT2; // Test SMCLK Output P2.2
- P5SEL |= BIT4 + BIT5; // Port select XT1
- REFCTL0 &= ~REFMSTR;
- UCSCTL6 &= ~(XT1OFF); // XT1 On
- UCSCTL6 |= XCAP_3; // Internal load cap
- // Loop until XT1 fault flag is cleared
- do
- UCSCTL7 &= ~XT1LFOFFG; // Clear XT1 fault flags
- }while (UCSCTL7&XT1LFOFFG); // Test XT1 fault flag
- // Initialize DCO to 5MHz
- __bis_SR_register(SCG0); // Disable the FLL control loop
- UCSCTL0 = 0x0000; // Set lowest possible DCOx, MODx
- UCSCTL1 = DCORSEL_5; // 2.5MHz - 6MHz
- UCSCTL2 = FLLD_0 + 152; // Set DCO Multiplier for 5MHz
- // (N + 1) * FLLRef = Fdco
- // (152 + 1) * 32768 = 5MHz
- // Set FLL Div = fDCOCLK/1
- UCSCTL3 = SELREF_2 + FLLREFDIV_0; // Reference of FLL select REFOCLK, fFLLREFCLK/1
- UCSCTL4 = SELA_3 + SELS_3 + SELM_3; // SMCLK = ADCLK = MCLK = DCOCLK
- UCSCTL5 = DIVPA_0 + DIVA_0 + DIVS_0 + DIVM_0; //
- __bic_SR_register(SCG0); // Enable the FLL control loop
- // 32 x 32 x 5 MHz / 32,768 Hz = 156250 = MCLK cycles for DCO to settle
- __delay_cycles(156250);
- do
- UCSCTL7 &= ~(XT2OFFG + XT1LFOFFG + DCOFFG); // Clear XT2,XT1,DCO fault flags
- SFRIFG1 &= ~OFIFG; // Clear fault flags
- }while (SFRIFG1 & OFIFG); // Test oscillator fault flag
复制代码 这样的设置是不是有问题啊?多谢
[ 本帖最后由 haiqibian 于 2013-11-8 21:57 编辑 ]
