3357|0
用DMA模式读写SD卡 [复制链接]
不好意思, 我知道这个问题问了很多次,可是我是一个新手,没有办法做到。
我模仿了以下的程式:
这是我的Code:
void WriteBlock_DMA(void){
//__IO uint32_t Status = 0;
uint8_t write_data[10] = {1, 2, 3, 4, 5, 6, 7, 8, 9, 0};
//SD_Init();
//Status = SD_WriteBlock(write_data, 0x00, SD_BLOCK_SIZE);
DMA_InitTypeDef DMA_TestStructure;
SD_Error rvalue = SD_RESPONSE_FAILURE;
SD_Init();
SD_CS_LOW();
//Enables the DMA1 peripheral clock.
RCC_AHBPeriphClockCmd(RCC_AHBPeriph_DMA1, ENABLE);
//Configuration of the DMA1 Channel4 - SPI2_RX
DMA_DeInit(DMA1_Channel5);
  DMA_TestStructure.DMA_PeripheralBaseAddr = (uint32_t)SD_SPI_DR_Address;
  DMA_TestStructure.DMA_MemoryBaseAddr = (uint32_t)write_data;
  DMA_TestStructure.DMA_DIR = DMA_DIR_PeripheralDST;
  DMA_TestStructure.DMA_BufferSize = SD_BLOCK_SIZE;
  DMA_TestStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;
  DMA_TestStructure.DMA_MemoryInc = DMA_MemoryInc_Enable;
  DMA_TestStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_Byte;
  DMA_TestStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_Byte;
  DMA_TestStructure.DMA_Mode = DMA_Mode_Normal;
  DMA_TestStructure.DMA_Priority = DMA_Priority_High;
  DMA_TestStructure.DMA_M2M = DMA_M2M_Disable;
  DMA_Init(DMA1_Channel5, &DMA_TestStructure);
SD_SendCmd(SD_CMD_SET_BLOCKLEN,SD_BLOCK_SIZE,0x00);
  SD_ReadByte();
  SD_ReadByte();
SPI_I2S_DMACmd(SD_SPI, SPI_I2S_DMAReq_Tx, ENABLE);
//DMA_ClearFlag(DMA1_FLAG_TC4);
SD_SendCmd(SD_CMD_WRITE_SINGLE_BLOCK, 0x00, 0xFF);
if (!SD_GetResponse(SD_RESPONSE_NO_ERROR))
    /*!< Send a dummy byte */
    SD_WriteByte(SD_DUMMY_BYTE);
    /*!< Send the data token to signify the start of the data */
    SD_WriteByte(0xFE);
DMA_Cmd(DMA1_Channel5, ENABLE);
while (!DMA_GetFlagStatus(DMA1_FLAG_TC5));
while(SPI_I2S_GetFlagStatus(SD_SPI, SPI_I2S_FLAG_TXE) == RESET);
SD_ReadByte();
    SD_ReadByte();
    /* Read data response */
    if (SD_GetDataResponse() == SD_DATA_OK)
        rvalue = SD_RESPONSE_NO_ERROR;
SD_CS_HIGH();
DMA_Cmd(DMA1_Channel5, DISABLE);
程式一直停在if (SD_GetDataResponse() == SD_DATA_OK),请问各位高手我有哪里没有考虑到的吗?
此帖出自stm32/stm8论坛
