6665|1
21
jlink v8识别不了LPC2148 [复制链接]
用jlink V8给目标板提供3.3V电压,就是把jlink 里面的跳线帽插到3.3V pin上
然后连接 2148,一直这样提示,试了两个2148了,都是这样的提示
我如果用目标板自己的电源,也是同样的提示
Feature(s): RDI,FlashDL,FlashBP,JFlash,GDBFull
VTarget = 3.300V
Info: Could not measure total IR len. TDO is constant high.
No devices found on JTAG chain. Trying to find device on SWD.
No device found on SWD.
Did not find any core.
J-Link>st
VTarget=3.306V
ITarget=0mA
TCK=1 TDI=0 TDO=1 TMS=0 TRES=0 TRST=1
Supported JTAG speeds:
- 48 MHz/n, (n>=4). => 12000kHz, 9600kHz, 8000kHz, ...
- Adaptive clocking
J-Link>hwinfo
HWInfo[00] = Target power is disabled
HWInfo[02] = 0mA        (ITarget)
HWInfo[03] = 0mA        (ITargetPeak)
HWInfo[04] = 0mA        (ITargetPeakOperation)
HWInfo[10] = 0ms        (ITargetMaxTime0)
HWInfo[11] = 0ms        (ITargetMaxTime1)
HWInfo[12] = 0ms        (ITargetMaxTime2)
J-Link>
jlink v8驱动用的是4.42a, 最新版的4.46 老是Request 1 bytes, received 0 bytes!!
所以用回老的
[ 本帖最后由 chary8088 于 2012-4-27 15:30 编辑 ]
截图
截图
此帖出自ARM技术论坛
21
自己UP下
此帖出自ARM技术论坛
有奖直播:当AI遇见仿真,会有什么样的电子行业革新之路?
第2场直播:融合热仿真与热测试提升产品可靠性
直播时间:04月17日 14:00 - 15:00
