11540|11
没有调用GPIO_EXTILineConfig为什么也能进中断 [复制链接]
刚刚开始学习STM32,现在遇到一个问题,不明白是为什么。
我按照教程上写了一个最简单的中断程序,就是按键 然后进中断,点亮led 按键是 PA0,led是PA2
按照教程上的写法
GPIO_InitTypeDef GPIO_InitStructure;
 NVIC_InitTypeDef NVIC_InitStructure;
 EXTI_InitTypeDef EXTI_InitStructure;
 RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA, ENABLE);
PA2 设置为输出
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
 GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
GPIO_Init(GPIOA, &GPIO_InitStructure);
PA0设置为输入
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0 ;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING; //选择输入模式为浮空输入
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;          //输出频率最大50MHz
GPIO_Init(GPIOA,&GPIO_InitStructure);
 NVIC_PriorityGroupConfig(NVIC_PriorityGroup_3);
 NVIC_InitStructure.NVIC_IRQChannel = EXTI0_IRQn;
 NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;
 NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0;
 NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
 NVIC_Init(&NVIC_InitStructure);
 GPIO_EXTILineConfig(GPIO_PortSourceGPIOA, GPIO_PinSource0);
 EXTI_InitStructure.EXTI_Line = EXTI_Line0;
 EXTI_InitStructure.EXTI_Mode = EXTI_Mode_Interrupt;
 EXTI_InitStructure.EXTI_Trigger = EXTI_Trigger_Falling;
 EXTI_InitStructure.EXTI_LineCmd = ENABLE;
 EXTI_Init(&EXTI_InitStructure);
以上配置没有问题 进中断后能正常点亮小灯!
但是我自己试验了一下,我去掉  PA0 设置为输入这段代码,或者去掉GPIO_EXTILineConfig(GPIO_PortSourceGPIOA, GPIO_PinSource0);,或者两者都去掉
还是能正常点亮小灯! 这是为什么??
GPIO_EXTILineConfig这个函数的作用是什么?参数GPIO_PinSource0是不是必须和EXTI_InitStructure.EXTI_Line = EXTI_Line0一致,为同一个口?
最求高手赐教
此帖出自stm32/stm8论坛
/**   * @brief  Selects the GPIO pin used as EXTI Line.   * @param  GPIO_PortSource: selects the GPIO port to be used as source for EXTI lines.   *   This parameter can be GPIO_PortSourceGPIOx where x can be (A..G).   * @param  GPIO_PinSource: specifies the EXTI line to be configured.   *   This parameter can be GPIO_PinSourcex where x can be (0..15).   * @retval None   */ void GPIO_EXTILineConfig(uint8_t GPIO_PortSource, uint8_t GPIO_PinSource) 初始应该是0,但是我发现在PA的前面几个脚不带这个也是可以的。   详情 回复 发表于 2018-3-2 10:13
我也遇到这个问题啊。。。
此帖出自stm32/stm8论坛
顶一下啊 高手们 这个问题应该很简单 请不吝赐教啊~
此帖出自stm32/stm8论坛
。。。还没有人回答一下吗。。。。晕啊
此帖出自stm32/stm8论坛
大侠们 帮帮忙啊
此帖出自stm32/stm8论坛
中断设置时少一句话把
EXTI_GenerateSWInterrupt(EXTI_Line0);
此帖出自stm32/stm8论坛
闁哄被鍎冲﹢鍛村嫉椤掆偓缁楁﹢宕楅妸鈺佸姤閻犱降鍔忛鎴︽晬瀹€鍐惧殲闁谎嗩嚙缂嶏拷闁瑰瓨鐗為埀顒婃嫹婵炲鍔岄崬锟�
此帖出自stm32/stm8论坛
赞赏
查看全部赞赏
此帖出自stm32/stm8论坛
给点个赞 嘿嘿 热心助人的精神必须得鼓励  详情 回复 发表于 2017-1-24 11:56
管理员
此帖出自stm32/stm8论坛
加EE小助手好友,
入技术交流群
EE服务号
精彩活动e手掌握
EE订阅号
热门资讯e网打尽
聚焦汽车电子软硬件开发
认真关注技术本身
加油!在电子行业默默贡献自己的力量!:)
4008
此帖出自stm32/stm8论坛
此帖出自stm32/stm8论坛
此帖出自stm32/stm8论坛
猜你喜欢
直播时间:4月22日(周二)10:00
直播奖励:京东卡、蓝牙温湿度计、定制水杯
