2120|0
2274SPI 通讯问题 [复制链接]
程序是这样的。但为什么当我SPI仿真的时候,接收和发送寄存器都会变,但在发送接的时候用示波器,量SIMO,SCK 一直是高电平并不是正常波形
请各位们指示下,小弟感激万分。
void initializeMSP430(void)
   int8 i = 0;
   WDTCTL = WDTPW + WDTHOLD;// Stop watchdog timer to prevent time out reset
   //DCOCTL |= DCO2|DCO1|DCO0;
   BCSCTL1 |= XT2OFF + XTS + DIVA0 + DIVA1;   // CLOCK SOURCE = LFXT1, Aclk = LFXT1/8
   BCSCTL2 |= SELM1 + SELS+DIVS0+DIVS1;                  // MCLK = LFXT1/2 MSCLK = LFXT1/2
   BCSCTL3 |= LFXT1S1+LFXT1OF; // LF = 4 - 16 M  LFXT1 oscillator fault
   do
    IFG1 &= ~OFIFG;                             // Clear OSCFault flag
    for (i = 0xFF; i > 0; i--){;}               // Time for flag to set
  }while((IFG1 & OFIFG));
           Configure the USCI in spi mode
void ConfigSPIMode(void)
   volatile unsigned char i ;
   i = 0;
   UCB0CTL0 = UCCKPH + UCCKPL + UCMSB + UCMST  + UCSYNC ;//+ UCMODE1
   UCB0CTL1 = UCSSEL1+UCSWRST;       // UCSSEL1+UCSSEL0 UCSI RESET
   P2DIR |= BIT2;                            // SPI CS OUTPUT
   P3DIR = 0x1D;
   P3OUT = 0x00;                            // 101101 P3.1 DI P3.2 DO P3.3 SCK P3.4 RX P3.5 TX
   P3SEL = 0x3F;
   UCB0CTL1 &= ~UCSWRST;              // SPI initialize
                                           //UCSI in spi syncronous mode  clock phase is 1  clock polarity is 1
   //IFG2 = 0x00;                             // transmit flag
}void SPITransmit(unsigned char Dat)
      UCB0TXBUF__SPI = Dat;
      while(!(IFG2 & UCB0TXIFG));
void main()
   init();
 do
    delayms(2);
    SPITransmit(0x55);
    delayms(2);
}while(1);
[ 本帖最后由 feimy 于 2011-11-18 11:57 编辑 ]
有奖直播:当AI遇见仿真,会有什么样的电子行业革新之路?
第2场直播:融合热仿真与热测试提升产品可靠性
直播时间:04月17日 14:00 - 15:00
