3457|4
66
求教 TI例程调试出问题 430F24X uart [复制链接]
// MSP430x24x Demo - USCI_A0, Ultra-Low Pwr UART 9600 RX/TX, 32kHz ACLK
 // Description: This program demonstrates a full-duplex 9600-baud UART using
 // USCI_A0 and a 32kHz crystal. The program will wait in LPM3, and receive
// a string1 into RAM, and echo back the complete string.
 // ACLK = BRCLK = LFXT1 = 32768Hz, MCLK = SMCLK = DCO ~1.045Mhz
 // Baud rate divider with 32768Hz XTAL @9600 = 32768Hz/9600 = 3.41
//* An external watch crystal is required on XIN XOUT for ACLK *//
                         // MSP430F249 //
//                 /|\    |                            XIN|-
//                  |     |                                 | 32kHz
//                     --|RST                XOUT |-
//                       |         P3.4 /UCA0TXD|------------>
 //                      |                                  | 9600 - 8N1
//                       |          P3.5/UCA0RXD|<------------
B. Nisarga
// Texas Instruments Inc.
 // September 2007
// Built with IAR Embedded Workbench Version: 3.42A
 #include "msp430x24x.h"
char string1[8];
char i;
char j = 0;
 void main(void)
        WDTCTL = WDTPW + WDTHOLD;        // Stop WDT
        P1DIR = 0xFF;                                     // All P1.x outputs
        P1OUT = 0;                                           // All P1.x reset
        P2DIR = 0xFF;                                    // All P2.x outputs
        P2OUT = 0;                                      // All P2.x reset
        P3SEL = 0x30;                                               // P3.4,5 = USCI_A0 TXD/RXD
        P3DIR = 0xFF;                                               // All P3.x outputs
        P3OUT = 0;                                                  // All P3.x reset
        P4DIR = 0xFF;                                                 // All P4.x outputs
        P4OUT = 0;                                                         // All P4.x reset
       UCA0CTL1 |= UCSSEL_1;                              // CLK = ACLK
        UCA0BR0 = 0x03;                                         // 32kHz/9600 = 3.41
        UCA0BR1 = 0x00;                                           //
       UCA0MCTL = UCBRS1 + UCBRS0;               // Modulation UCBRSx = 3
       UCA0CTL1 &= ~UCSWRST;                          // **Initialize USCI state machine**
        IE2 |= UCA0RXIE;                                           // Enable USCI_A0 RX interrupt
          __bis_SR_register(LPM3_bits + GIE);          // Enter LPM3, interrupts enabled }
 // USCI A0/B0 Transmit ISR
 #pragma vector=USCIAB0TX_VECTOR
__interrupt void USCI0TX_ISR(void)
          UCA0TXBUF = string1[i++];          // TX next character
          if (i == sizeof string1)                   // TX over?
         IE2 &= ~UCA0TXIE;                     // Disable USCI_A0 TX interrupt
 // USCI A0/B0 Receive ISR
#pragma vector=USCIAB0RX_VECTOR
 __interrupt void USCI0RX_ISR(void)
          string1[j++] = UCA0RXBUF;
          if (j > sizeof string1 - 1)
              i = 0;
              j = 0;
              IE2 |= UCA0TXIE;                      // Enable USCI_A0 TX interrupt
              UCA0TXBUF = string1[i++]; }
我分析的 格式 N,8,1,9600
程序说的是 发什么 接收窗显示什么
 端口号 我绝对没有错
我的错误状况是
 发送任意字符串后 接收在字节数在自加 接手区无显示 (非十六进制显示)
                               接收在字节数在自加 接收到若干 00 (十六进制显示)
 求教 我哪里出了问题!
贴个代码 贴的 一个空格没有    手动调了半天
[ 本帖最后由 shirl 于 2011-11-7 21:09 编辑 ]
无奇偶校验,8比特模式,停止位是1位。 串口有收到的话,基本可以定位成时钟和显示的问题。 可以用调试器在线调试状态下查看,MSP430到底接收到了什么,这样再定位是单片机接收还是发送的过程中出的问题  详情 回复 发表于 2011-11-8 10:42
5014
裸片初长成(初级)
找到了一个我以前验证过的代码
char string1[8];
char i;
char j = 0;
void main(void)
  UCA0BR1 = 0x00;                           //
    i = 0;
    j = 0;
5014
裸片初长成(初级)
无奇偶校验,8比特模式,停止位是1位。
66
回复 板凳 wstt 的帖子
版主来回复 很是激动啊 !
但是 我没发现你的程序和我的有哪里不同!   都是TI给的例程吗
66
AA
搞出来了
程序 是 没问题 的   当然也不是波特率的问题了
串口调试 助手  没用  !  换一个调试  可以的
那个什么疼的!!!
猜你喜欢
有奖直播 | AI之眼——安森美图像传感器 报名中
直播主题:AI之眼——安森美图像传感器
报名观看直播、直播间提问、填写问卷均有机会获得精美礼品!
