器件型号:STM32F103VE 问题:单步调试发现没有进入中断程序,请高手指教! 代码: void NVIC_Configuration(void) { NVIC_InitTypeDef NVIC_InitStructure;//定义NVIC_InitTypeDef类型变量NVIC_InitStructure #ifdef VECT_TAB_RAM /* Set the Vector Table base location at 0x20000000 --设置量表的基地位置在0x20000000(在RAM上)*/ NVIC_SetVectorTable(NVIC_VectTab_RAM, 0x0); #else /* VECT_TAB_FLASH */ /* Set the Vector Table base location at 0x08000000 --设置量表的基地位置在0x08000000(在FLASH上)*/ NVIC_SetVectorTable(NVIC_VectTab_FLASH, 0x0); #endif /* Enable and configure IRQ channel */ NVIC_InitStructure.NVIC_IRQChannel = USB_LP_CAN1_RX0_IRQn; //中断通道 NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0; //主优先级0 NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0; //次优先级0 NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE; //中断使能 NVIC_Init(&NVIC_InitStructure); } TestStatus CAN_Interrupt(void) { CAN_InitTypeDef CAN_InitStructure; CAN_FilterInitTypeDef CAN_FilterInitStructure; CanTxMsg TxMessage; u32 i = 0; //u8 TransmitMailbox; /* CAN register init */ CAN_DeInit(CAN1); CAN_StructInit(&CAN_InitStructure); /* CAN cell init */ CAN_InitStructure.CAN_TTCM=DISABLE; CAN_InitStructure.CAN_ABOM=DISABLE; CAN_InitStructure.CAN_AWUM=DISABLE; CAN_InitStructure.CAN_NART=DISABLE; CAN_InitStructure.CAN_RFLM=DISABLE; CAN_InitStructure.CAN_TXFP=DISABLE; CAN_InitStructure.CAN_Mode=CAN_Mode_LoopBack; CAN_InitStructure.CAN_SJW=CAN_SJW_1tq; CAN_InitStructure.CAN_BS1=CAN_BS1_7tq; CAN_InitStructure.CAN_BS2=CAN_BS2_8tq; CAN_InitStructure.CAN_Prescaler=9; CAN_Init(CAN1,&CAN_InitStructure); /* CAN filter init */ // CAN_FilterInitStructure.CAN_FilterNumber=1; // CAN_FilterInitStructure.CAN_FilterMode=CAN_FilterMode_IdMask; // CAN_FilterInitStructure.CAN_FilterScale=CAN_FilterScale_32bit; // i=(0x11<<21)|(0x34<<3); // CAN_FilterInitStructure.CAN_FilterIdHigh=(i>>16); // CAN_FilterInitStructure.CAN_FilterIdLow=(i&0xffff); // CAN_FilterInitStructure.CAN_FilterMaskIdHigh=0x0; // CAN_FilterInitStructure.CAN_FilterMaskIdLow=0x0; // CAN_FilterInitStructure.CAN_FilterFIFOAssignment=CAN_FIFO0; // CAN_FilterInitStructure.CAN_FilterActivation=ENABLE; // CAN_FilterInit(&CAN_FilterInitStructure); CAN_FilterInitStructure.CAN_FilterNumber=0; CAN_FilterInitStructure.CAN_FilterMode=CAN_FilterMode_IdMask; CAN_FilterInitStructure.CAN_FilterScale=CAN_FilterScale_32bit; CAN_FilterInitStructure.CAN_FilterIdHigh=0x0000; CAN_FilterInitStructure.CAN_FilterIdLow=0x0000; CAN_FilterInitStructure.CAN_FilterMaskIdHigh=0x0000; CAN_FilterInitStructure.CAN_FilterMaskIdLow=0x0000; CAN_FilterInitStructure.CAN_FilterFIFOAssignment=0; CAN_FilterInitStructure.CAN_FilterActivation=ENABLE; CAN_FilterInit(&CAN_FilterInitStructure); /* CAN FIFO0 message pending interrupt enable */ CAN_ITConfig(CAN1,CAN_IT_FMP0, ENABLE); /* initialize the value that will be returned */ ret = 0xFF; /* transmit 1 message */ TxMessage.StdId=0x12; TxMessage.ExtId=0x34; TxMessage.IDE=CAN_ID_EXT; TxMessage.RTR=CAN_RTR_DATA; TxMessage.DLC=2; TxMessage.Data[0]=0xDE; TxMessage.Data[1]=0xCA; CAN_Transmit(CAN1,&TxMessage); /* receive message with interrupt handling */ i=0; while((ret == 0xFF) && (i < 0xFF)) { i++; } if (i == 0xFF) { ret=0; } /* disable interrupt handling */ CAN_ITConfig(CAN1,CAN_IT_FMP0, DISABLE); return (TestStatus)ret; } void USB_LP_CAN1_RX0_IRQHandler(void) { CanRxMsg RxMessage; RxMessage.StdId=0x00; RxMessage.ExtId=0x00; RxMessage.IDE=0; RxMessage.DLC=0; RxMessage.FMI=0; RxMessage.Data[0]=0x00; RxMessage.Data[1]=0x00; CAN_Receive(CAN1,CAN_FIFO0, &RxMessage); if((RxMessage.StdId==0x12) && (RxMessage.ExtId==0x34) && (RxMessage.IDE==CAN_ID_EXT) && (RxMessage.DLC==2) && ((RxMessage.Data[1]|RxMessage.Data[0]<<8)==0xDECA)) { ret = 1; } else { ret = 0; } }
