2795|0
61
使用LM3S串口与AVR单片机串口设置 [复制链接]
UART-----FIFO
 #include "inc/hw_ints.h"
#include "inc/hw_memmap.h"
#include "inc/hw_types.h"
#include "driverlib/debug.h"  //单步调试
#include "driverlib/gpio.h"
#include "driverlib/interrupt.h"
//#include "driverlib/rom.h" //使用rom里面固化的api函数,以节约flash空间
#include "driverlib/sysctl.h"
#include "driverlib/systick.h"
#include "driverlib/uart.h"
#include"stdio.h"
#define PINS GPIO_PIN_5
#define UARTCharPutNB UARTCharPutNonBlocking
void
uartInit(void)
  SysCtlPeripheralEnable(SYSCTL_PERIPH_UART0);//使能UART模块
  SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOA);//使能RX和TX所在的端口PA//
  GPIOPinTypeUART(GPIO_PORTA_BASE,   //配置RX和TX
                   GPIO_PIN_0|GPIO_PIN_1); //为收发功能//
 UARTConfigSetExpClk(UART0_BASE,SysCtlClockGet(),//配置GPIO端口 ,系统时钟频率
        9600,UART_CONFIG_WLEN_8|     // 波特率9600,数据位8
  UART_CONFIG_PAR_NONE|      //效检位:无
  UART_CONFIG_STOP_ONE);     //停止位1
  UARTEnable(UART0_BASE); //使能UART0
  UARTFIFOLevelSet(UART0_BASE,      //配置FIFO中断触发深度
                    UART_FIFO_TX2_8,    //发送FIFO为2/8深度(4B)
     UART_FIFO_RX6_8);    //接收FIFO深度6/8深度(12B)
  UARTIntEnable(UART0_BASE,UART_INT_TX);  //使能发送中断//
  IntEnable(INT_UART0);  //能使UART0中断
  IntMasterEnable();  //打开总中断//
  UARTEnable(UART0_BASE); //使能UART端口//
 void LED_INIT(void)
   SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOE);//使能外设GIOPE
    GPIOPadConfigSet(GPIO_PORTE_BASE, PINS,
                     GPIO_STRENGTH_4MA,
                     GPIO_PIN_TYPE_STD);//配置管脚驱动,驱动电流2MA其实已足够
    GPIODirModeSet(GPIO_PORTE_BASE, PINS, GPIO_DIR_MODE_OUT);//设置管脚输出
  SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOF);//使能外设GIOPF
    GPIOPadConfigSet(GPIO_PORTF_BASE, GPIO_PIN_2|GPIO_PIN_3,   //PF2,PF3//
                     GPIO_STRENGTH_4MA,
    GPIODirModeSet(GPIO_PORTF_BASE, GPIO_PIN_2|GPIO_PIN_3, GPIO_DIR_MODE_OUT);//设置管脚输出
const char TxData[]="0123456789ABCDEFGHIJKLMNOPQRSTUVWXYZ\r\n";
volatile int TxIndex=0;
volatile int n=0;   //显示中断次数作用,因为板用8MHZ所以不宜定义长字符//
volatile tBoolean TxEndFlag = false;
//填充发送FIFO(填满FIFO之后就退出,不会等待)
void
TxFIFOFill(void)
  char c;
  for(;;)
    c=TxData[TxIndex];
 if(c=='\0')     //若填充完毕//
   TxEndFlag=true;  //发送结束标志位,并退出//
   break;
 if(UARTSpaceAvail(UART0_BASE)) //若FIFO中有可用空间
   UARTCharPutNB(UART0_BASE,c); //填充发FIFO
   TxIndex++;
 } else{       //若没有空则跳出//
         break;
void UARTput(const char *pucBuffer) //通过UART发送字符串//
    while(*pucBuffer)
        // 通过字符串指针发送数据
        UARTCharPutNonBlocking(UART0_BASE, *pucBuffer++);
int
main(void)
   char S[40];
   SysCtlClockSet(SYSCTL_OSC_MAIN|SYSCTL_XTAL_8MHZ|
                  SYSCTL_USE_OSC|SYSCTL_SYSDIV_1); //系统时钟
  uartInit();
  LED_INIT();
  TxFIFOFill();
 for(;;)
    if(TxEndFlag)   //若发送结束则跳出//
   TxEndFlag=false;
   break;
 sprintf(S,"n=%d\r\n",n); //显示中断次数//
  UARTput(S);    //发送数据//
  for(;;)
    if(n>4)
  GPIOPinWrite(GPIO_PORTE_BASE, PINS, ~PINS);//输出高电低PE5LED亮
 }else{
        GPIOPinWrite(GPIO_PORTE_BASE, PINS, PINS);//输出高电低PE5LED亮表明已进入中断
//  UART0中断服务函数
void UART0_ISR(void)
    unsigned long ulStatus;
    ulStatus = UARTIntStatus(UART0_BASE, true);             //  读取当前中断状态
    UARTIntClear(UART0_BASE, ulStatus);                     //  清除中断状态
 // GPIOPinWrite(GPIO_PORTE_BASE, PINS, ~PINS);//输出高电低PE5LED亮
    if (ulStatus & UART_INT_TX)                             //  若是发送中断
       TxFIFOFill();
    n++;
  //GPIOPinWrite(GPIO_PORTE_BASE, PINS, PINS);//输出高电低PE5LED亮表明已进入中断
从以上的设置看出的确32位的LM3S比8位的AVR要强得多。
