5638|1
我这个DSP程序为什么进不了中断呢? [复制链接]
用的DSP是TMS320C6745,是SPI1的接收程序。运行时,无法进入SPI接收中断程序,总是停在主程序中的while(1)这里,进不了中断。
附上程序。
#include "Initial.h"
extern CSL_SpiRegsOvly spiRegs;
extern void intcVectorTable(void);
Uint16 Data[256] = {0};
CSL_IntcRegsOvly intcRegs = (CSL_IntcRegsOvly)CSL_INTC_0_REGS;
Uint8  flag  = 0;
Uint16 Rdata = 0;
void main(void)
 SystemTargetInit();
 intcRegs->INTMUX1 = 43;
 ISTP = (unsigned int)intcVectorTable;
 ICR = 0xFFF0;// 清中断标志
 IER |= 0x12;//使能中断IE4
 CSR |=0x1; //使能所有的可屏蔽中断
 while(1)
  if(flag == 0)
    flag = 1;
  // CSL_FINS(spiRegs->SPIDAT1,SPI_SPIDAT1_TXDATA,0xffff);
   //spiRegs->SPIDAT0 = 0x11;
interrupt void SPI_Interrupt(void)
 static Uint8 i = 0;
 ICR = 0xFFF0; //写1清中断标志
 spiRegs->SPIFLG |= 0x00000100;//清SPI标志
 asm(" NOP 1 ");
 //while((spiRegs->SPIBUF & 0x80000000) != 0x80000000)
    Rdata = spiRegs->SPIBUF;
 Data = Rdata;
 i++;
// Rdata++;
 flag = 0;
 asm(" NOP 1 ");
编译是成功的,下载到板子中运行就是不进中断。
