4398|0
MX53 Industrial Embedded WinCE7 System, Yuanying [复制链接]
To be one of technical leader company, in past few year Yuanying Tech always focus on embedded system solution offering, from low end to high end. Our platform including MX25, MX28, MX35 and MX51. From Nov of last year, Yuanying Tech. have started to design MX53 platform based on WinCE OS. Now, we have successfully finished this project and launched MX53 Windows Embedded Compact 7 system platform --- YY- i.MX53W
i.MX53 is Soc processor based on an ARM Cortex A8 as core architecture (with Trust Zone), CPU frequency up to 1Ghz ~1.2Ghz, own 32 Kbyte L1 Instruction Cache and Data Cache, and 256 Kbyte L2 Cache as well. Integrate Neon Coprocessor to enhance its Vector floating point operation ability. To boost multimedia performance, the following hardware accelerators are integrated: VPU – Video processing unit, IPU – Image processing unit, GPU 3D – Graphic Processing Unit (OpenGL ES 2.0 AMD Z430) and GPU 2D – Graphic Processing Unit (OpenVG1.1 AMD Z160). Support multiple format of HD1080P video decode and multiple format of 720P video encodealso support 1080P TV analog video signal output directlyDual camera CSI interface and dual display interface largely enhance MX53 application field. By means of DVF and Smart Speed technology for smart power managementAt the equal performance condition, which can run at the lower power consumption, and perform the great multimedia result
i.MX53W is an WinCE7 System Platform based on Windows Embedded Compact 7, adopt FAT file system, designed by Yuan-ying Technology. i.MX53L own plentiful peripheral interface, such as USB HOST, USB OTG, TVE OutputDVIVGALVDSCamera CSI inputSDIO and so on i.MX53W is widely applied various field, including: HD internet monitor/Automotive Infotainment, industrial computer and thin client machine(cloud computer), MID , Home Media Terminal, V2IP, Factory Automation, HMI design, etc. The dual display feature is the most suitable platform for education equipment. Customer need only focus on the application software design, and largely shorten the time to market cycle.
    Hardware Brief
CPU Processor
Ø        MX535/6
Ø        ARM Cortex A8 1~1.2GHz
Ø        32 Kbyte L1 I-Cache and D-Cache, 256K L-2 Cache
Ø        NEON Coprocessor for VFPU
Ø        Hardware Graphic Accelerator OpenGL ES 2.0 --- 3D
Ø        Hardware Graphic Accelerator OpenVG 1.1 – 2D
Ø        VPU/IPU for Video Procession Unit and Image Processing Unit
Memory
Ø        RAM1GB DDR3 ( 256MB X 4)
Ø        NAND Flash2GB
Ø        SD card or NAND Flash boot
Peripheral Interface
Ø        USB Interface1 x HS USB OTG, up to 480 Mbps, Integrated USB Phy3 x HS USB Host
Ø        SD Two SD card slot (one of it for system boot)
Ø        FEC 10/100M Ethernet with IEEE 1588 QUICC engine
Ø        UART 5 x UART Connector
Ø        PATA with U-DMA mode 5 and SATA II supported
Ø        2 x CAN interface and MLB interface
Ø        3x I2S/SSI/AC97 interface
A-V output
Ø        LCD 7” LVDS 1024X600
Ø        VGA/HDMI interface
Ø        LVDSsupport dual LVDS display the same time (default one 7” LVDS panel)
Ø        Audio-In MIC-in /LINE-in
Ø        Audio-Out:  Line out / Headphones
Clock and Power Supply
Ø        RTC External clock, real time clock supported
Ø        Power Supply 5V, 2A output
Wireless Communication
Ø        Support 802.11 b/g/n (option)
Ø        Support GPRS/WCDMA (optional for customer)
PCB Board Structure and Size
Ø        Bottom Board   13.5cm x 15cm     2- layers
Ø        Mini System Board 8cm x 9cm      6- layers
       Visiting www.yuan-ying.com for more details.
