3987|5
275
信号,变量,常量之间赋值的比较 [复制链接]
大家帮我看看下面的代码编译出错,问题找不出来,多谢指教
library ieee ;
use ieee.std_logic_1164.all ;
use ieee.std_logic_arith.all ;
use ieee.std_logic_unsigned.all ;
ENTITY RGBdianpingshiyan is
   PORT (
   CLK1      :IN  STD_LOGIC;
   RESET   :IN  STD_LOGIC;
   RO    :out    std_logic_vector(5 downto 0);
   GO    :out    std_logic_vector(5 downto 0);
   BO    :out    std_logic_vector(5 downto 0)
END RGBdianpingshiyan;
ARCHITECTURE arch OF RGBdianpingshiyan is
signal V                   :STD_LOGIC_VECTOR(8 DOWNTO 0);
signal H                   :STD_LOGIC_VECTOR(8 DOWNTO 0);
SIGNAL read_enb:STD_LOGIC;
signal VSYNC          :STD_LOGIC;
signal HSYNC          :STD_LOGIC;
signal DE       :STD_LOGIC;
constant  VS_Total_CLK     : integer  :=336; --Back Porch+VS_CLK+Front Porch ==qianlang(14)+320+houlang(2)
constant  HS_Total_CLK     : integer  :=736; --Back Porch+HS_CLK+Front Porch==qianlang(14)+720+houlang(2)
constant  vS_Back_Porch        : integer  :=14; --back porch =14.
constant  HS_Back_Porch        : integer  :=14; --back porch =14.
constant  VS_CLK      : integer  :=320;--320 --Panel Size VS 320*240
constant  HS_CLK      : integer  :=240;--240 --Panel Size HS
BEGIN
PROCESS(CLK1)      --THIS BLOCK IS PRODUCE BASE CLK
BEGIN
 IF CLK1'EVENT AND CLK1='1' THEN
   IF (V=VS_Total_CLK AND H=HS_Total_CLK) THEN
    V <="000000000";
    H <="000000000";
   ELSIF H=HS_Total_CLK THEN
    V <=V+1;
    H <="000000000";
   ELSE
    H <=H+1;
   end if;
  else
   V <="000000000";
   H <="000000000";
 END IF;
END PROCESS;
PROCESS(CLK1)               --VSYNC
BEGIN
  IF (V=0 AND H=0) THEN
   VSYNC <='0';
  ELSIF (V=2 AND H=0) THEN  --3
   VSYNC <='1';
  END IF;
 END IF;
END PROCESS;
PROCESS(CLK1)                --HSYNC
BEGIN
 IF RESET='0' THEN
  HSYNC <='0';
 ELSIF CLK1'EVENT AND CLK1='1' THEN
  IF H=0 THEN
   HSYNC <='0';
  ELSIF H=2 THEN
   HSYNC <='1';
  END IF;
 END IF;
END PROCESS;
PROCESS(CLK1)                  --DE
BEGIN
 IF RESET='0' THEN
  DE <='1';
  read_enb <='1';
  IF V<VS_Back_Porch OR V >(VS_Back_Porch+VS_CLK) THEN  --Vsync Back Porch,(Vsync Back Porch+Vsync)
   READ_ENB <='1';
   DE <='1';
  ELSIF H=(HS_Back_Porch-1) THEN --> -1
   READ_ENB <='0';
  ELSIF H=HS_Back_Porch THEN --> not add
   DE <='0';
  ELSIF H=(HS_Back_Porch+HS_CLK-1) THEN  --> -1
   READ_ENB <='1';
  ELSIF H=(HS_Back_Porch+HS_CLK) THEN --> not add
   DE <='1';
  END IF;
 END IF;
END PROCESS;
PROCESS(CLK1)
Variable  HS_Back_Porch        : integer range 0 to 750 :=14; --back porch =14.
BEGIN
 IF RESET='0' THEN
  RO <="000000";
  GO <="000000";
  BO <="000000";
 ELSIF CLK1'EVENT AND CLK1='1' then -----Color Bar
   if h>=HS_Back_Porch and h< (HS_Back_Porch+30) then    --Red, 240/8=30
           RO <="111111";
           GO <="000000";
           BO <="000000";
   elsif h>= (HS_Back_Porch+30) and h <(HS_Back_Porch+60) then --Green
           RO <="000000";
           GO <="111111";
           BO <="000000";
   elsif h>= (HS_Back_Porch+60) and h <(HS_Back_Porch+90) then --Blue
           RO <="000000";
           GO <="000000";
           BO <="111111";
   elsif h>= (HS_Back_Porch+90) and h <(HS_Back_Porch+120) then --R&G
           RO <="111111";
           GO <="111111";
           BO <="000000";
   elsif h>= (HS_Back_Porch+120) and h <(HS_Back_Porch+150) then --R&B
           RO <="111111";
           GO <="000000";
           BO <="111111";
   elsif h>= (HS_Back_Porch+150) and h <(HS_Back_Porch+180) then --G&B
           RO <="000000";
           GO <="111111";
           BO <="111111";
   elsif h>= (HS_Back_Porch+180) and h <(HS_Back_Porch+210) then --White
           RO <="111111";
           GO <="111111";
           BO <="111111";
   elsif h>= (HS_Back_Porch+210) and h <(HS_Back_Porch+240) then --Black
           RO <="000000";
           GO <="000000";
           BO <="000000";
   else
           RO <="000000";
           GO <="000000";
           BO <="000000";
end if;
end if;
END PROCESS;
END Arch;
编译后出现:
Error (10818): Can't infer register for "H[0]" at RGBdianpingshiyan.vhdl(39) because it does not hold its value outside the clock edge
Error (10818): Can't infer register for "H[1]" at RGBdianpingshiyan.vhdl(39) because it does not hold its value outside the clock edge
Error (10818): Can't infer register for "H[2]" at RGBdianpingshiyan.vhdl(39) because it does not hold its value outside the clock edge
Error (10818): Can't infer register for "H[3]" at RGBdianpingshiyan.vhdl(39) because it does not hold its value outside the clock edge
Error (10818): Can't infer register for "H[4]" at RGBdianpingshiyan.vhdl(39) because it does not hold its value outside the clock edge
Error (10818): Can't infer register for "H[5]" at RGBdianpingshiyan.vhdl(39) because it does not hold its value outside the clock edge
Error (10818): Can't infer register for "H[6]" at RGBdianpingshiyan.vhdl(39) because it does not hold its value outside the clock edge
Error (10818): Can't infer register for "H[7]" at RGBdianpingshiyan.vhdl(39) because it does not hold its value outside the clock edge
Error (10818): Can't infer register for "H[8]" at RGBdianpingshiyan.vhdl(39) because it does not hold its value outside the clock edge
Error (10822): HDL error at RGBdianpingshiyan.vhdl(39): couldn't implement registers for assignments on this clock edge
我不知道什么原因导致的H的值不确定,请大家帮忙看看,同样的问题存在与V。
此帖出自FPGA/CPLD论坛
PROCESS(CLK1) --THIS BLOCK IS PRODUCE BASE CLK BEGIN IF CLK1'EVENT AND CLK1='1' THEN IF (V=VS_Total_CLK AND H=HS_Total_CLK) THEN V <="000000000"; H <="000000000"; ELSIF H=HS_Total_CLK THEN V <=V+1; H <="000000000"; ELSE H <=H+1; end if; else V <="000000000"; H <="000000000"; END IF; END PROCESS;   你的IF CLK1'EVENT AND CLK1='1  THEN            ------------------        ELSE           ---------------------        END IF;   上面的这种表达方法不符合硬件电路的描述。   不能用ELSE  详情 回复 发表于 2011-8-18 09:11
275
自己顶起,增加人气!!!
此帖出自FPGA/CPLD论坛
275
eeleader 速度为兄弟我指点啊
此帖出自FPGA/CPLD论坛
275
现在还是无人问津啊
此帖出自FPGA/CPLD论坛
6892
       ELSE
       END IF;
不能用ELSE
此帖出自FPGA/CPLD论坛
个人签名一个为理想不懈前进的人,一个永不言败人!
欢迎光临网上店铺!
275
多谢指点,看的太多了,这居然都没看出来,我想到其他地方去了,高手就是高手啊,
此帖出自FPGA/CPLD论坛
