8171|4
144
串口中断接收,IntMasterEnable是否是必须的? [复制链接]
刚做了串口中断的小程序,发现IntMasterEnable加不加都可以。串口中断接收,IntMasterEnable是否是必须的?
那你都这样了,不就是不必要  详情 回复 发表于 2017-7-25 22:22
149
我也觉得系统上电后,好像默认总中断是打开的。。
33
回复 楼主 ebuffalo 的帖子
Cortex-M3上电默认是允许中断的到其内核的。
//! \return Returns \b true if interrupts were disabled when the function was
//! called or \b false if they were initially enabled.
tBoolean
IntMasterEnable(void)
    // Enable processor interrupts.
    return(CPUcpsie());
#if defined(ccs)
unsigned long
CPUcpsie(void)
    // Read PRIMASK and enable interrupts.
    __asm("    mrs     r0, PRIMASK\n"
          "    cpsie   i\n"
          "    bx      lr\n");
    // The following keeps the compiler happy, because it wants to see a
    // return value from this function.  It will generate code to return
    // a zero.  However, the real return is the "bx lr" above, so the
    // return(0) is never executed and the function returns with the value
    // you expect in R0.
    return(0);
#endif
[ 本帖最后由 beloved 于 2011-7-27 10:03 编辑 ]
PRIMASK
PRIMASK
131
回复 楼主 ebuffalo 的帖子
虽然是默认的,最好加上,这样才是写程序的好习惯。
那你都这样了,不就是不必要
