STM32串口清中断后下次再接收数据会不会再次进入中断 我调试的是必须复位
STM32串口清中断后下次再接收数据会不会再次进入中断 我调试的是不能 必须复位才能接收新的数据 请问大家有知道怎么回事吗?
代码如下:
/* Includes ------------------------------------------------------------------*/ #include "stm32f10x.h" /* Private typedef -----------------------------------------------------------*/ /* Private define ------------------------------------------------------------*/ /* Private macro -------------------------------------------------------------*/ /* Private variables ---------------------------------------------------------*/ USART_InitTypeDef USART_InitStructure; USART_ClockInitTypeDef USART_ClockInitStructure; ErrorStatus HSEStartUpStatus; /* Private function prototypes -----------------------------------------------*/ void RCC_Configuration(void); void GPIO_Configuration(void); void NVIC_Configuration(void); /* Private functions ---------------------------------------------------------*/
/******************************************************************************* * Function Name : main * Description : Main program * Input : None * Output : None * Return : None *******************************************************************************/ int main(void) { #ifdef DEBUG debug(); #endif
/* System Clocks Configuration */ RCC_Configuration(); /* NVIC configuration */ NVIC_Configuration();
/* Configure the GPIO ports */ GPIO_Configuration();
/* USART1 configured as follow: - BaudRate = 9600 baud - Word Length = 8 Bits - Two Stop Bit - Odd parity - Hardware flow control disabled (RTS and CTS signals) - Receive and transmit enabled - USART Clock disabled - USART CPOL: Clock is active low - USART CPHA: Data is captured on the second edge - USART LastBit: The clock pulse of the last data bit is not output to the SCLK pin */ GPIO_PinRemapConfig(GPIO_Remap_USART1,ENABLE); /*AFIO->MAPR|=(uint32_t)0x04;*/ // clear USART1 remap
USART_InitStructure.USART_BaudRate = 9600; USART_InitStructure.USART_WordLength = USART_WordLength_8b; USART_InitStructure.USART_StopBits = USART_StopBits_1; USART_InitStructure.USART_Parity = USART_Parity_No; USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None; USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx; USART_ClockInitStructure.USART_Clock = USART_Clock_Disable; //禁用USART时钟 时钟低电平活动 USART_ClockInitStructure.USART_CPOL = USART_CPOL_Low; //时钟极性,数据低电平有效 USART_ClockInitStructure.USART_CPHA = USART_CPHA_2Edge; //外部时钟相位,数据在第二个时钟捕捉 USART_ClockInitStructure.USART_LastBit = USART_LastBit_Disable; //禁用最后一位,最后数据位的时钟脉冲不输出到SCLK引脚
/* Configure the USART1 */ USART_Init(USART1, &USART_InitStructure); USART_ClockInit(USART1,&USART_ClockInitStructure); /* Enable the USART Transmoit interrupt: this interrupt is generated when the USART1 transmit data register is empty */ USART_ITConfig(USART1, USART_IT_TXE, ENABLE);
/* Enable the USART Receive interrupt: this interrupt is generated when the USART1 receive data register is not empty */ USART_ITConfig(USART1, USART_IT_RXNE, ENABLE);
/* Enable USART1 */ USART_Cmd(USART1, ENABLE);
while(1) { } }
/******************************************************************************* * Function Name : RCC_Configuration * Description : Configures the different system clocks. * Input : None * Output : None * Return : None *******************************************************************************/ void RCC_Configuration(void) { /* RCC system reset(for debug purpose)将RCC寄存器从新设置为默认值 */ RCC_DeInit();
/* Enable HSE 打开外部高速时钟晶振*/ RCC_HSEConfig(RCC_HSE_ON);
/* Wait till HSE is ready 等待外部高速时钟晶振工作*/ HSEStartUpStatus = RCC_WaitForHSEStartUp();
if(HSEStartUpStatus == SUCCESS) { /* HCLK = SYSCLK 设置AHB时钟 设置高速总线时钟=系统时钟*/ RCC_HCLKConfig(RCC_SYSCLK_Div1); /* PCLK2 = HCLK 设置高速AHB时钟 设置低速总线2时钟=高速总线时钟*/ RCC_PCLK2Config(RCC_HCLK_Div1);
/* PCLK1 = HCLK/2 设置低速AHB时钟 设置低速总线1时钟=高速时钟的二分频*/ RCC_PCLK1Config(RCC_HCLK_Div2);
/* Flash 2 wait state 令Flash处于等待状态,2是针对高频时钟的*/ FLASH_SetLatency(FLASH_Latency_2); /* Enable Prefetch Buffer 使能flash预读取缓冲区*/ FLASH_PrefetchBufferCmd(FLASH_PrefetchBuffer_Enable);
/* PLLCLK = 8MHz * 9 = 72 MHz 利用锁相环将外部8MHz晶振9倍频到72MHz */ RCC_PLLConfig(RCC_PLLSource_HSE_Div1, RCC_PLLMul_9);
/* Enable PLL 使能锁相环 */ RCC_PLLCmd(ENABLE);
/* Wait till PLL is ready 等待锁相环输出稳定*/ while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET) { }
/* Select PLL as system clock source 将锁相环输出设置为系统时钟*/ RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK);
/* Wait till PLL is used as system clock source 判断PLL是否是系统时钟*/ while(RCC_GetSYSCLKSource() != 0x08) { } } /* Enable GPIOA and USART1 clocks 使能外围接口总线时钟,开串口时钟*/ RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB | RCC_APB2Periph_USART1| RCC_APB2Periph_AFIO, ENABLE);
/******************************************************************************* * Function Name : GPIO_Configuration * Description : Configures the different GPIO ports. * Input : None * Output : None * Return : None *******************************************************************************/ void GPIO_Configuration(void) { GPIO_InitTypeDef GPIO_InitStructure;
/* Configure USART1 Tx (PB6) as alternate function push-pull */ GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6; GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP; GPIO_Init(GPIOB, &GPIO_InitStructure);
/* Configure USART1 Rx (PB7) as input floating */ GPIO_InitStructure.GPIO_Pin = GPIO_Pin_7; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING; GPIO_Init(GPIOB, &GPIO_InitStructure); }
/******************************************************************************* * Function Name : NVIC_Configuration * Description : Configures the nested vectored interrupt controller. * Input : None * Output : None * Return : None *******************************************************************************/ void NVIC_Configuration(void) { NVIC_InitTypeDef NVIC_InitStructure;
#ifdef VECT_TAB_RAM /* Set the Vector Table base location at 0x20000000 */ NVIC_SetVectorTable(NVIC_VectTab_RAM, 0x0); #else /* VECT_TAB_FLASH */ /* Set the Vector Table base location at 0x08000000 */ NVIC_SetVectorTable(NVIC_VectTab_FLASH, 0x0); #endif
/* Enable the USART1 Interrupt */ NVIC_InitStructure.NVIC_IRQChannel = USART1_IRQn; NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0; NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0; NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE; NVIC_Init(&NVIC_InitStructure); }
中断处理函数是:void USART1_IRQHandler(void) { if(USART_GetITStatus(USART1, USART_IT_RXNE) == SET) { /* Read one byte from the receive data register */ RxBuffer[RxCounter++] = (USART_ReceiveData(USART1) & 0x7F); /* Clear the USART1 Receive interrupt */ USART_ClearITPendingBit(USART1, USART_IT_RXNE);
if(RxCounter == NbrOfDataToRead) { /* Disable the USART Receive interrupt */ USART_ITConfig(USART1, USART_IT_RXNE, DISABLE); USART_ITConfig(USART1, USART_IT_TXE, ENABLE); TxCounter=0; p = RxBuffer; } }
if(USART_GetITStatus(USART1, USART_IT_TXE) == SET) { /* Write one byte to the transmit data register */ USART_SendData(USART1, p[TxCounter++]); while(USART_GetFlagStatus(USART1, USART_IT_TXE)==RESET)
/* Clear the USART1 transmit interrupt */ USART_ClearITPendingBit(USART1, USART_IT_TC);
if(p==TxBuffer&&TxCounter == NbrOfDataToTransfer) { /* Disable the USART1 Transmit interrupt */ USART_ITConfig(USART1, USART_IT_TXE, DISABLE); } if(p==RxBuffer&&TxCounter==RxCounter) { /* Disable the USART1 Transmit interrupt */ USART_ITConfig(USART1, USART_IT_TXE, DISABLE); } } if(USART_GetFlagStatus(USART1,USART_FLAG_ORE)==SET) { USART_ClearFlag(USART1,USART_FLAG_ORE); //清溢出位 USART_ReceiveData(USART1); //读DR } }
已经清楚中断标志位了,为什么发送新的数据时不能覆盖掉以前的数据?
