板上有烧好的U-BOOT,开起电源打印以下信息: Texas Instruments X-Loader 1.44 (Jun 24 2010 - 15:48:14) Starting OS Bootloader... U-Boot 2009.11 ( 9月 29 2010 - 14:33:05) OMAP34xx/35xx-GP ES1.0, CPU-OPP2 L3-165MHz AM3517EVM Board + LPDDR/NAND I2C: ready DRAM: 256 MB NAND: 512 MiB In: serial Out: serial Err: serial Die ID #0dcc0000000000000155dc1402014022 Net: davinci_emac_initialize Ethernet PHY: GENERIC @ 0x00 DaVinci EMAC Hit any key to stop autoboot: 0 AM3517_EVM #
证明U-BOOT已经启来了,为了适合我的要求,修改了一些参数,看看修改后的参数: AM3517_EVM # print baudrate=115200 bootfile=uImage loadaddr=0x82000000|115200 8N1 | NOR | Minicom 2.3 | VT102 | 离线 console=ttyS2,115200n8 mmcargs=setenv bootargs console=${console} root=/dev/mmcblk0p2 rw rootfstype=ext3 rootwait nandargs=setenv bootargs console=${console} root=/dev/mtdblock4 rw rootfstype=jffs2 loadbootscript=fatload mmc 0 ${loadaddr} boot.scr bootscript=echo Running bootscript from mmc ...; source ${loadaddr} loaduimage=fatload mmc 0 ${loadaddr} uImage mmcboot=echo Booting from mmc ...; run mmcargs; bootm ${loadaddr} nandboot=echo Booting from nand ...; run nandargs; nand read ${loadaddr} 280000 400000; bootm ${loadaddr} dieid#=0dcc0000000000000155dc1402014022 ethact=DaVinci EMAC old_bootcmd=if mmc init; then if run loadbootscript; then run bootscript; else if run loaduimage; then run mmcboot; else run nandboot; fi; fi; else run nandi rootpath=/work/rootfs ethaddr=92:EF:10:78:87:BA gateway=192.168.0.1 myboot=setenv bootargs root=/dev/nfs rw nfsroot=192.168.0.101:/work/rootfs ip=192.168.0.102:192.168.0.101:192.168.0.1:255.255.255.0:::off console=ttyS2,11528 mybootcmd=run mryboot;nand read 0x82000000 280000 400000;bootm 0x82000000 bootargs=noinitrd init=/linuxrc root=/dev/nfs rw nfsroot=192.168.0.1:/home/mry/nfs/fs ip=192.168.0.2:192.168.0.1:255.255.255.0 console=ttyS2,115200n8 filesize=B fileaddr=82000000 netmask=255.255.255.0 mrybootcmd=run mryboot;tftp 0x82000000 uImage;bootm 0x82000000 bootcmd=run mrybootcmd bootdelay=4 gatewayip=192.168.1.1 ipaddr=192.168.1.11 serverip=192.168.1.5 mryboot=setenv bootargs noinitrd init=/linuxrc root=/dev/nfs rw nfsroot=192.168.1.5:/home/mry/nfs/fs ip=192.168.1.11:192.168.1.5:192.168.1.1:255.255.255.0 c8 stdin=serial stdout=serial stderr=serial
Environment size: 1693/131068 bytes
本人用的是minicom,参数显示不全,大概意思是: bootcmd=run mrybootcmd mrybootcmd=run mryboot;tftp 0x82000000 uImage;bootm 0x82000000 mryboot=setenv bootargs noinitrd init=/linuxrc root=/dev/nfs rw nfsroot=192.168.1.5:/home/mry/nfs/fs ip=192.168.1.11:192.168.1.5:192.168.1.1:255.255.255.0 c8 通过tftp协议从主机(192.168.1.5)下载内核景象(uImage)到ARM以总线地址0x82000000为开始的地方(RAM),并从该地方启动LINUX,当然,这些是需要在主机方的TFTP服务端的支持的(把uImage放在tftp文件夹下) 设置linux的启动参数为nfs挂载文件系统,这也需要在主机上开启NFS服务,和放置好文件系统;文件系统放在/home/mry/nfs/fs下 看看启动过程吧: AM3517_EVM # boot Using DaVinci EMAC device TFTP from server 192.168.1.5; our IP address is 192.168.1.11 Filename 'uImage'. Load address: 0x82000000 Loading: T T ################################################################# ################################################################# #####################################T #####T ####################### ################################################################# #####################################################T ############ ################################################################# ################################################################# ################################################################# ##### done Bytes transferred = 2683740 (28f35c hex) ## Booting kernel from Legacy Image at 82000000 ... Image Name: Linux-2.6.32 Image Type: ARM Linux Kernel Image (uncompressed) Data Size: 2683676 Bytes = 2.6 MB Load Address: 80008000 Entry Point: 80008000 Verifying Checksum ... OK Loading Kernel Image ... OK OK
Starting kernel ...
Uncompressing Linux.......................................................................................................................................... Linux version 2.6.32 (root@seed) (gcc version 4.3.3 (Sourcery G++ Lite 2009q1-203) ) #189 Tue Dec 7 12:48:33 CST 2010 CPU: ARMv7 Processor [411fc087] revision 7 (ARMv7), cr=10c53c7f CPU: VIPT nonaliasing data cache, VIPT nonaliasing instruction cache Machine: OMAP3517/AM3517 EVM Memory policy: ECC disabled, Data cache writeback AM3517 ES1.0 (l2cache iva sgx neon isp ) SRAM: Mapped pa 0x40200000 to va 0xfe400000 size: 0x100000 Reserving 4194304 bytes SDRAM for VRAM Built 1 zonelists in Zone order, mobility grouping on. Total pages: 65024 Kernel command line: noinitrd init=/linuxrc root=/dev/nfs rw nfsroot=192.168.1.5:/home/mry/nfs/fs ip=192.168.1.11:192.168.1.5:192.168.1.1:255.255.255.0 cons8 PID hash table entries: 1024 (order: 0, 4096 bytes) Dentry cache hash table entries: 32768 (order: 5, 131072 bytes) Inode-cache hash table entries: 16384 (order: 4, 65536 bytes) Memory: 256MB = 256MB total Memory: 249984KB available (4844K code, 441K data, 168K init, 0K highmem) Hierarchical RCU implementation. NR_IRQS:368 Clocking rate (Crystal/Core/MPU): 26.0/332/500 MHz GPMC revision 5.0 IRQ: Found an INTC at 0xfa200000 (revision 4.0) with 96 interrupts Total of 96 interrupts on 1 active controller OMAP GPIO hardware version 2.5 OMAP clockevent source: GPTIMER1 at 32768 Hz Console: colour dummy device 80x30 Calibrating delay loop... 499.92 BogoMIPS (lpj=1949696) Mount-cache hash table entries: 512 CPU: Testing write buffer coherency: ok regulator: core version 0.5 NET: Registered protocol family 16 mux: Could not set signal i2c2_scl mux: Could not set signal i2c2_sda mux: Could not set signal i2c3_scl mux: Could not set signal i2c3_sda Display option not selected OMAP DMA hardware revision 4.0 bio: create slab <bio-0> at 0 SCSI subsystem initialized usbcore: registered new interface driver usbfs usbcore: registered new interface driver hub usbcore: registered new device driver usb i2c_omap i2c_omap.1: bus 1 rev3.12 at 400 kHz regulator: VDCDC1: 1200 mV normal regulator: VDCDC2: 3300 mV normal regulator: VDCDC3: 1800 mV normal regulator: LDO1: 1800 mV normal regulator: LDO2: 3300 mV normal i2c_omap i2c_omap.2: bus 2 rev3.12 at 400 kHz pca953x 2-0021: failed reading register pca953x: probe of 2-0021 failed with error -5 i2c_omap i2c_omap.3: bus 3 rev3.12 at 400 kHz tca6416-keypad 3-0020: failed reading register tca6416-keypad: probe of 3-0020 failed with error -5 pca953x 3-0021: failed reading register pca953x: probe of 3-0021 failed with error -5 Switching to clocksource 32k_counter musb_hdrc: version 6.0, cppi4.1-dma, otg (peripheral+host), debug=0 AM3517 OTG revision 4ea41001, PHY f0036a2, control 00 musb_hdrc: USB OTG mode controller at d0810000 using DMA, IRQ 71 NET: Registered protocol family 2 IP route cache hash table entries: 2048 (order: 1, 8192 bytes) TCP established hash table entries: 8192 (order: 4, 65536 bytes) TCP bind hash table entries: 8192 (order: 3, 32768 bytes) TCP: Hash tables configured (established 8192 bind 8192) TCP reno registered UDP hash table entries: 256 (order: 0, 4096 bytes) UDP-Lite hash table entries: 256 (order: 0, 4096 bytes) NET: Registered protocol family 1 RPC: Registered udp transport module. RPC: Registered tcp transport module. RPC: Registered tcp NFSv4.1 backchannel transport module. AM3517 Linux PSP version 03.00.01.06 (AM3517EVM) NetWinder Floating Point Emulator V0.97 (double precision) VFS: Disk quotas dquot_6.5.2 Dquot-cache hash table entries: 1024 (order 0, 4096 bytes) Installing knfsd (copyright (C) 1996 okir@monad.swb.de). JFFS2 version 2.2. (NAND) © 2001-2006 Red Hat, Inc. yaffs Dec 7 2010 12:39:13 Installing. msgmni has been set to 488 alg: No test for stdrng (krng) io scheduler noop registered io scheduler deadline registered io scheduler cfq registered (default) OMAP DSS rev 2.0 OMAP DISPC rev 3.0 OMAP VENC rev 2 OMAP DSI rev 1.0 Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled serial8250.0: ttyS0 at MMIO 0x4806a000 (irq = 72) is a ST16654 serial8250.1: ttyS1 at MMIO 0x4806c000 (irq = 73) is a ST16654 serial8250.2: ttyS2 at MMIO 0x49020000 (irq = 74) is a ST16654 console [ttyS2] enabled brd: module loaded loop: module loaded omap2-nand driver initializing NAND device: Manufacturer ID: 0xec, Chip ID: 0xdc (Samsung omap2-nand.0) NAND bus width 16 instead 8 bit No NAND device found!!! NAND device: Manufacturer ID: 0xec, Chip ID: 0xdc (Samsung NAND 512MiB 3,3V 8-bit) Creating 5 MTD partitions on "omap2-nand.0": 0x000000000000-0x000000080000 : "xloader-nand" 0x000000080000-0x000000240000 : "uboot-nand" 0x000000240000-0x000000280000 : "params-nand" 0x000000280000-0x000000780000 : "linux-nand" 0x000000780000-0x000020000000 : "jffs2-nand" vcan: Virtual CAN interface driver CAN device driver interface TI High End CAN Controller Driver 0.7 failed to get can_stb ti_hecc ti_hecc.1: device registered (reg_base=d0870000, irq=24) usbcore: registered new interface driver hwa-rc usbmon: debugfs is not available ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver ~~~~~~~~~~~~~~~~~~~~~0!!!!!!!!!!!~~~~~~~~~` ~~~~~~~~~~~~~~~~~~~~~1!!!!!!!!!!!~~~~~~~~~` ehci-omap ehci-omap.0: OMAP-EHCI Host Controller ehci-omap ehci-omap.0: new USB bus registered, assigned bus number 1 ehci-omap ehci-omap.0: irq 77, io mem 0x48064800 ehci-omap ehci-omap.0: USB 2.0 started, EHCI 1.00 hub 1-0:1.0: USB hub found hub 1-0:1.0: 3 ports detected ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver usbcore: registered new interface driver hwa-hc usbcore: registered new interface driver wusb-cbaf Initializing USB Mass Storage driver... usbcore: registered new interface driver usb-storage USB Mass Storage support registered. g_ether gadget: using random self ethernet address g_ether gadget: using random host ethernet address usb0: MAC ea:cf:26:63:88:88 usb0: HOST MAC 0a:70:15:63:dc:18 g_ether gadget: Ethernet Gadget, version: Memorial Day 2008 g_ether gadget: g_ether ready musb_hdrc musb_hdrc: MUSB HDRC host driver musb_hdrc musb_hdrc: new USB bus registered, assigned bus number 2 hub 2-0:1.0: USB hub found hub 2-0:1.0: 1 port detected mice: PS/2 mouse device common for all mice tsc2003 init tsc2003 probe tsc2003 begin GPIO176 irqqq :336 input: tsc2003 as /class/input/input0 tsc2003 x:3056 y:3200 z:2096 bate:4080 rtc-s35390a 1-0030: error resetting chip rtc-s35390a: probe of 1-0030 failed with error -5 Linux video capture interface: v2.00 vpfe_init vpfe-capture vpfe-capture: v4l2 device registered vpfe-capture vpfe-capture: video device registered tvp514x 3-005c: tvp514x 3-005c decoder driver registered !! vpfe-capture vpfe-capture: v4l2 sub device tvp5146 registered vpfe_register_ccdc_device: DM6446 CCDC DM6446 CCDC is registered with vpfe. OMAP Watchdog Timer Rev 0x31: initial timeout 60 sec mmci-omap-hs mmci-omap-hs.1: err -16 configuring card detect usbcore: registered new interface driver usbhid usbhid: USB HID core driver Advanced Linux Sound Architecture Driver Version 1.0.21. No device for DAI AD73311 Asahi Kasei AK4104 ALSA SoC Codec Driver No device for DAI AK4535 Cirrus Logic CS4270 ALSA SoC Codec Driver No device for DAI PCM3008 HiFi No device for DAI SSM2602 No device for DAI tlv320aic23 No device for DAI tlv320aic3x No device for DAI UDA134X No device for DAI WM8510 HiFi No device for DAI WM8728 No device for DAI WM8750 No device for DAI WM8971 usb 1-1: new high speed USB device using ehci-omap and address 2 No device for DAI WM8990 ADC/DAC Primary No device for DAI omap-mcbsp-dai-0 No device for DAI omap-mcbsp-dai-1 No device for DAI omap-mcbsp-dai-2 No device for DAI omap-mcbsp-dai-3 No device for DAI omap-mcbsp-dai-4 OMAP3517 / AM3517 EVM SoC init asoc: tlv320aic3x <-> omap-mcbsp-dai-0 mapping ok Failed to add route IN1L->LINE1L dapm: tlv320aic3x: configuring unknown pin Line Out ALSA device list: #0: am3517evm (tlv320aic3x) TCP cubic registered NET: Registered protocol family 17 NET: Registered protocol family 15 can: controller area network core (rev 20090105 abi 8) NET: Registered protocol family 29 can: raw protocol (rev 20090105) can: broadcast manager protocol (rev 20090105 t) Power Management for TI OMAP3. VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 1 Console: switching to colour frame buffer device 100x30 omapdss DPI: Could not find exact pixel clock. Requested 35087 kHz, got 35086 kHz davinci_emac_probe: using random MAC addr: 6e:16:26:a8:2e:4b emac-mii: probed drivers/rtc/hctosys.c: unable to open rtc device (rtc0) omapdss DPI error: display already enabled omap_vout omap_vout: 'lcd' Display already enabled omapdss DPI error: display already enabled omap_vout omap_vout: 'lcd' Display already enabled omap_vout omap_vout: Buffer Size = 3686400 omap_vout omap_vout: : registered and initialized video device 1 omap_vout omap_vout: Buffer Size = 3686400 omap_vout omap_vout: : registered and initialized video device 2 hub 1-1:1.0: USB hub found hub 1-1:1.0: 4 ports detected eth0: attached PHY driver [Generic PHY] (mii_bus:phy_addr=ffffffff:00, id=22161a) Sending DHCP and RARP requests . PHY: ffffffff:00 - Link is Up - 100/Full .., OK IP-Config: Got DHCP answer from 0.0.0.0, my address is 192.168.1.8 IP-Config: Complete: device=eth0, addr=192.168.1.8, mask=255.255.255.0, gw=192.168.1.1, host=192.168.1.8, domain=, nis-domain=(none), bootserver=0.0.0.0, rootserver=192.168.1.5, rootpath= Looking up port of RPC 100003/2 on 192.168.1.5 Looking up port of RPC 100005/1 on 192.168.1.5 VFS: Mounted root (nfs filesystem) on device 0:12. Freeing init memory: 168K
Please press Enter to activate this console. [root@MY2440 /]# 正如我们期望的的,系统启动起来了,虽然在下载uImage的时候不是一封风顺,但是总会成功的,呵呵 看一些系统的基本信息: [root@MY2440 /proc]# df -h Filesystem Size Used Available Use% Mounted on /dev/root 9.4G 6.3G 2.6G 71% / none 122.2M 0 122.2M 0% /tmp none 122.2M 0 122.2M 0% /var [root@MY2440 /proc]# cat cpuinfo Processor : ARMv7 Processor rev 7 (v7l) BogoMIPS : 499.92 Features : swp half thumb fastmult vfp edsp neon vfpv3 CPU implementer : 0x41 CPU architecture: 7 CPU variant : 0x1 CPU part : 0xc08 CPU revision : 7
Hardware : OMAP3517/AM3517 EVM Revision : 0020 Serial : 0000000000000000 [root@MY2440 /proc]# uname -a Linux MY2440 2.6.32 #189 Tue Dec 7 12:48:33 CST 2010 armv7l GNU/Linux
总结:不做BSP(在次厂家已做好了这些),系统的启动还是比较容易的,如果要自己搞bsp,那么难度就不是这么一点了,并不是说只有作bsp的人牛逼,术业有专攻,合理分配而已
