RomBOOT
> INFO : Low Level Init : OK Dataflash init OK Starting eboot ... Master Clock is 48054841 Hz Master Clock is 49920000 Hz Master Clock is 49920000 Hz 5)5)晧諠佂丧叡仴攻靴叡ラ晳伖构构构?-?)=-5)5)5?酵綑褋]箲捷蛠 ?选暽箷褋 浇驯厬暽? 降到箒1?吷鍋Y暽ソ箒殴艁 榨毖?鍋裳伾僚艁泡榱砷派5)5呁暽? 苯嵀仴蛠彦迳亮亮??)Microsoft Windows CE 5.0 Ethernet Bootloader for the AT91SAM926xEK board Adaptation performed by ADENEO (c) 2007
Master Clock is 49920000 Hz Master Clock is 49920000 Hz WARNING : LoadEBootCFG: No valid Eboot configuration found. INFO : Loading default bootloader settings
Press [ENTER] to download now or [SPACE] to cancel. Initiating image download in 0 seconds System ready! Preparing for download...
Master Clock is 49920000 Hz *** InitializatioHY GetLinkSpeed failed Check if the chip select is correctly initialized ERROR: Failed to initialize DM9000 Ethernet controller. WARNING : No Ethernet link detected... Check the connection ! INFO : Retrying in few seconds. (press <SPACE> or <ENTER> to cancel) Initiating image download in 0 seconds Master Clock is 49920000 Hz *** Initialization of the DM9000 Ethernet controler ****
Waiting for Link by the PHY No link by the PHY GetLinkSpeed failed Check if the chip select is correctly initialized ERROR: Failed to initialize DM9000 Ethernet controller. WARNING : No Ethernet link detected... Check the connection ! INFO : Retrying in few seconds. (press <SPACE> or <ENTER> to cancel) Initiating image download in 0 seconds Master Clock is 49920000 Hz *** Initialization of the DM9000 Ethernet controler ****
Waiting for Link by the PHY No link by the PHY GetLinkSpeed failed Check if the chip select is correctly initialized ERROR: Failed to initialize DM9000 Ethernet controller. WARNING : No Ethernet link detected... Check the connection ! INFO : Retrying in few seconds. (press <SPACE> or <ENTER> to cancel) Initiating image download in 9 secondsERROR : Critical error on initialization
SpinForever ...
[ 本帖最后由 hill1987 于 2011-5-25 17:16 编辑 ]
