3669|9
67
flash读写 [复制链接]
unsigned int g=8800;
FlashErase(0x3080);
Flash_ww(0x3080,g);
b=*(unsigned int *)0x3080;
取出的数据正确
unsigned int g=88800;
FlashErase(0x3080);
Flash_ww(0x3080,g);
取出的数据不正确
改成
unsigned long g=88800;
FlashErase(0x3080);
Flash_ww(0x3080,g);
b=*(unsigned ilong *)0x3080;
仍然 取出的数据不正确
请问为什么
你的Flash_ww()应这样定义: Flash_ww( const unsigned int address , const unsigned long g) { unsigned char i ; unsigned int *p = address ; unsigned int *pg = ( unsigned int * )(&g) ; //set FCTL1,FCTL2,FCTL3 ............. //write g to the address for( i= sizeof( unsigned long ) / sizeof( unsigned int ) ; i > 0 ; i-- ) { *p++ = *pg++ ; } //reset FCTL1,FCTL2,FCTL3 .......... }  详情 回复 发表于 2008-7-10 10:43
57
溢出
可是改成 unsigned long g=68800;
也不行
62
写入正确否?
FlashErase(0x3080);
Flash_ww(0x3080,g);
b=*(unsigned long *)0x3080;
写入正确呀
77
长整数在FLASH中怎么读写呀
ding
63
unsigned int 类型数据溢出. 88800已大于unsigned unt 的最大值65535
umsigned long int 的READ或WRITE与 unsigned int 一样,只不过在IAR3.4x中,其长为32位,占4字节
55
那我在IAR3。4X中对长整数在FLASH中怎么操作
78
你的Flash_ww()应这样定义:
unsigned char i ;
*p++ = *pg++ ;
