//Only CS is low and AWE is high,then read option is valid! assign D = (((!CS) && AWE)==1)?MEM[A]:12'bz; //Only AOE is low,then output data stored in the RAM to the inner FPGA modoule. assign D = ((CLK && (!AOE))==1)?MEM[A]:12'bz;
always @(CS or AWE or A or D) begin if((!CS) && (!AWE))//Only CS and AWE are low,then write option is valid! begin MEM[A] = D; end else MEM[A] = MEM[A]; end endmodule
Synthesizing Unit <SRAM>. Related source file is "SRAM.v". WARNING:Xst:737 - Found 12-bit latch for signal <MEM_7>. WARNING:Xst:737 - Found 12-bit latch for signal <MEM_6>. WARNING:Xst:737 - Found 12-bit latch for signal <MEM_5>. WARNING:Xst:737 - Found 12-bit latch for signal <MEM_4>. WARNING:Xst:737 - Found 12-bit latch for signal <MEM_3>. WARNING:Xst:737 - Found 12-bit latch for signal <MEM_2>. WARNING:Xst:737 - Found 12-bit latch for signal <MEM_1>. WARNING:Xst:737 - Found 12-bit latch for signal <MEM_0>. Found 12-bit tristate buffer for signal <D>. Found 12-bit 8-to-1 multiplexer for signal <$n0000> created at line 44. Summary: inferred 12 Multiplexer(s). inferred 24 Tristate(s). Unit <SRAM> synthesized.
============================================================ * Low Level Synthesis * ============================================================ Loading device for application Rf_Device from file '3s400.nph' in environment C:\Xilinx. WARNING:Xst:2040 - Unit SRAM: 12 multi-source signals are replaced by logic (pull-up yes): N11, N13, N15, N17, N19, N21, N23, N25, N27, N5, N7, N9.
