4286|5
75
请教:自己做的c2812板子,连不上仿真器 [复制链接]
错误提示如下:
Error connecting to the target:
Error 0x80000240/-291
Fatal Error during: Initialization, OCS,
This error was generated by TI\'s USCIF driver.
SC_ERR_TST_MEASURE <-291>
The built-in scan-path length measurement has failed. This indicates
that the JTAG controller cannot reliably communicate with
the target DSP\'s and micro-controllers at that frequency.
Try specifying the scan-path lengths in the board configuration
file because the built-in scan-path reliability tests cannot be
performed without knowledge of the scan-path length.
Sequence ID: 0
Error Code: -291
Error Class: 0x80000240
Board Name: F2812 XDS560 Emulator
Cpu Name: CPU_1
Abort:                Close Code Composer Studio.
Retry:                Try to connect to the target again.
Cancel:                Remain disconnected from the target
Diagnostic:        Run diagnostic utility.
谢谢!
我也遇到这样的问题,望各位高手指点,联系QQ7112376  详情 回复 发表于 2009-3-17 07:32
85
楼上的用XDS560仿真器调试吗?一般不会出现这样的问题,建议先用标准的DSP板卡连接试试看。
[ 本贴由 edward 于 2008-2-25 11:42 AM 最后编辑 ]
81
我也有相同的问题,我的DSP上电后,jtag的tms脚的电平不正常,其他电平都正常,而且dsp的时钟输出也是正确的,我怀疑焊板子的时候这个引脚虚焊了不知楼主的怎么样?
这块就行了
又新焊了一块,这次jtag各引脚的上电电平完全正确,接仿真器也通了
90
我也遇到了相同的问题,仍未解决,请教高手
站长推荐上一条 2/10 下一条
有奖探索 | 和村田一起,深挖 GNSS 开发!
活动时间:即日起-5月11日
活动奖励:智能手环、螺丝刀套装、双肩包
