4481|1
TMS320LF2407A程序烧不进去?unable to clear [复制链接]
**** Begin Sector Clear Operation ****
OK: Flash Algorithm loaded into DSP memory
OK: Write sector value 0x0001 to symbol PRG_options
OK: Set Breakpoint at PRG_stop
OK: Running flash algorithm
OK: DSP Halted
OK: Read status value 0x0000 from symbol PRG_status
OK: PC set to PRG_erase
OK: DSP Halted
Error: Read status value 0x0001 from symbol PRG_status
Flash algorithm failed during clear operation
之前是好好的,可能真是FLASH坏了!?
2407的flash是很脆弱,我以前用过一块,烧了3次就挂了,心疼啊!  详情 回复 发表于 2007-11-30 01:53
65
直播时间:4月22日(周二)10:00
直播奖励:京东卡、蓝牙温湿度计、定制水杯
